Question about Kohler K-11390-S Polished Stainless Transitional 12 Inch Grab Bar K-11390
TRANSIT VAN WILL NOT GO IN GEAR CAN I ADJUST CLUTCH CABLE AND HOW
  • 111 Answers
If it has a cable, yes-if it's hydraulic,if it's not leaking,yes, the adjuster will be on the firewall or at the clutch arm, hope this helps
Posted on Jan 31, 2010
How do I get it in reverse it in stuck in forward
Didn't get info on which car or van your working on but a lot of gearchanges can jam due to heavy handed gear changes check top of gearbox turret remove screws se if end of gearchange stick has broken off remove and look inside box get large screwdriver and lever cutouts in selectors and lever into line and if stick not broken then refit some ford transit turrets seize and stick in gear lubrication is the answer also transit has a crosspin that snaps needs retapped if cable or lever make sure not seized
Feb 02, 2015 | Cars & Trucks
Have a 2033 auto transit van, high roof. At the lights the transmission lights come on. The van has then dropped out of gear and I have to put it back in gear by pressing the button. When its on a hill...
sorry i have absolutly no idea ,is this a ford transit or another make with a similar name also is this a semi automatic with paddle controls on the steering wheel or a floor change type changer/selector?
Mar 15, 2014 | Cars & Trucks
Ford transit diesel, clanking noise from gearbox, drives perfect noise is there in 1st 2nd 3rd gear but not in 4th. changed oil but no difference?
an auto transit ,in europe thats sacrilage ,the best white van mans van around reduced to be being a granny wagon,have you no pride in its heritage ??? the fastest getaway bank hold up van in the business in 60s reduced to being tied up in a autobox ,tell me what engine you have and i have a manual gearbox shipped forewith ,The shame of it a macho mans white van turned into a granny wagon -----
Nov 20, 2010 | Ford Transit Connect Cars & Trucks
Put a new clutch cable on my escort but no good as i can not adjust the pedal
LIFT THE CLUTCH PEDAL TO DISENGAGE THE ADJUSTING MECHANISM.THIS MUST BE DONE DURING CABLE INSTALLATION AS FAILURE TO DO SO WILL RESULT IN DAMAGE TO THE SELF ADJUSTER MECHANISM.INSERT THE CLUTCH CABLE THROUGH THE DASH PANEL AND THE DASH PANEL GROMMET.( WARNING ) BESURE THE CLUTCH CABLE IS ROUTED UNDER THE BRAKE LINES AND NOT TRAPPED AT THE SPRING TOWER BY THE BRAKE LINES IF EQUIPPED WITH POWER STEERING ROUTE THE CABLE INBOARD OF THE POWER STEERING HOSE.PUSH THE CLUTCH CABLE THROUGH THE INSULATOR ON THE STOP BRACKET AND THROUGH THE RECESS BETWEEN THE PEDAL AND THE GEAR QUADRANT.LIFT THE CLUTCH PEDAL TO RELEASE THE PAWL ROTATE THE GEAR QUADRANT FORWARD AND HOOK THE CABLE INTO THE GEAR QUADRANT.INSTALL THE CLUTCH SHIELD ON THE BRAKE PEDAL SUPPORT BRACKET.ON THE TEMPO OR TOPAZ INSTALL THE PANEL ABOVE THE CLUTCH PEDAL.USING A PIECE OF WIRE CORD OR TAPE SECURE THE PEDAL IN THE UPMOST POSITION.INSERT THE CLUTCH CABLE THROUGH THE INSULATOR AND CONNECT THE CABLE TO THE CLUTCH RELEASE LEVER IN THE ENGINE COMPARTMENT.REMOVE THE DEVICE USED TO TEMPORARILY SECURE THE PEDAL AGAINST ITS STOP.ADJUST THE CLUTCH BY DEPRESSING THE CLUTCH PEDAL SEVERAL TIMES.INSTALL THE AIR CLEANER.
May 31, 2010 | 1995 Ford Escort
Clutch adjustment
Hi! U need to re adjust the cable
Jan 27, 2009 | 1995 Volkswagen Golf
Diagram of Location of a Starter Motor on Ford Transit 2002/2003
i have a 2001y reg transit tipper and i think the starter motor is going when i go to start it like grinds then some times it starts perfect
Nov 24, 2008 | Ford Festiva Cars & Trucks
Changed the gear box on the ford transit van
did you reset the computer after replacing it?
remove the positive battery cable for 10 mins.....
Nov 15, 2008 | 2000 Ford Expedition
Kohler K-11390-S Polished Stainless Transitional 12 Inch Grab Bar K-11390 Logo
595 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
