Question about Dell Latitude D505 Notebook
My laptop will not make a good connection with my charger. I can wiggle it and sometimes make it make a connection, but the slightest movement can shake it out again. Very annoying... what can I do?
    President:
  • 2,600 Answers
The power port or DC jack needs to be replaced. There are small tabs within the jack that hold tension and proper positioning of the adapter plug. When these tesion bands wear down or the plug gets pilled out and pushed in over time, there is less and less contact between the components.
Posted on Jan 31, 2010
My charger is lose an it sometimes charges an sometiems doesnt
sounds like a short. could be the charger, but could be the connector on the laptop. does it wiggle at all?
if you isolate the cable (don't wiggle the plugged in part) and move it around, can you cause the charging to stop and start by bending your cable? if so, it is definitely a short in your charger and you'd be best off ordering a replacement if you don't want to deal with the hassle.
Oct 16, 2013 | Acer Aspire 5736z 4460 Laptop
Battery will charge but connection of charger has to be just right to connect and then cannot touch it. will wiggle around
If you are sure that you have to wiggle your laptop charger to let your laptop charge normally, it means your hp laptop power jack is loose or dead. Either you need to replace it or fix it.
While if you are good at tech and you have a good knowledge of laptop, you may fix the power socket by yourself based on the following instructions article:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Jan 16, 2013 | HP Pavilion Computers & Internet
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Random continuous beeping from Acer Aspire and i bought it in September so it is a brand new computer and it does this either way is plugged in or not and it happens randomly
Mine beeps if the charger isn't plugged in completely or connecting completely. It does it persistently if not connected completely and I tap the keyboard (slightest movement) good luck.
Nov 29, 2012 | Acer Aspire 5100 Notebook
It wont charge im holding it right nw hoping it wont shut down help fast
If your laptop won't hold a charge and you need to hod the connection in order for it to stay on, you may have a power jack issue. The power jack on the laptop may have been moved around from moving the laptop while connected or wiggling around the connection, and needs to be re-soldered back on the motherboard.
Also, just before taking that step, try using a different or brand new charger. Sometimes the pin inside a charger might be bent or broken, therefore not making a proper connection with the power jack.
Hope this helps.
Jun 25, 2011 | Computers & Internet
My Inspiron B130 laptop wont charge. i have to wiggle the charger around, and sometimes that doesnt work.
Either the plug on the laptop is bad, or the charger cord is faulty. If you have a friend that has the same charger you can use it to find out which.
Laptop chargers do go bad...
Aug 04, 2010 | Dell Inspiron B130 Notebook
Hp dv5 charger port seems to have u loose connection. if i wiggle the plug i can get it to charge sometimes. what do i do? is this something that can be fixed?
You need to diagnose first if the problem is the charger or the port of the laptop itself if it is possible to try a different charger to check if the cause of the problem is the charger if not then what i suggest is for you to check if you still have a warranty for your HP laptop so that you can bring it to the repair center free of cost because it might be the motherboard that it is causing the problem
Jul 31, 2010 | HP Pavilion dv5-1000us Notebook PC
Compaq Presario V3000 charger stopped working and now buzzes
Unfortunately there are no perfect cables, and especially in case of a laptop, when you move it around a lot, roll the cable for travel etc. it gets bent a lot, especially in the place where the elastic cable goes into the hard plug or into the charger case. The conductors inside and the inner insulation finally break, giving at first intermittent connection (what you experienced before), and finally short-circuits the cable, resulting in charger damage.
You should be fine just replacing the charger, unless all this wiggling around didn't break the laptop power socket.
When looking for a replacement charger, note the voltage of the original (it should be exactly the same in the new one), the maximum current amperage (this should be same or - better - higher than original), and the size of plug.
Good luck :)
Jan 23, 2010 | HP Compaq Presario v3000z Notebook
Computer works by Battery only but not A/C cord
Your DC Jack Is Most Likely Failing From What You Describe....
The DC Jack Is The Port Where Your Charger Cord Plugs Into..
If Wiggled Enough, It Will Pry Loose From The Motherboard And Eventually It Will Begin To Short Out The Power, If Left Unrepaired, It Will Eventually Lose All Means Of Charging/Powering On Due To The Solder Being Burnt Away From The Positive Pins That Connect To The Mainboard....
You Might Want To Test Your AC Adapter With A Multimeter For Positive Power and Correct Voltage .. Sometimes A Broken Cord Will test Good If The Break Is Making Contact when testing....
So When Testing the cord... Slightly wiggle it to see if indeed there is a break in it or not...
Feb 06, 2009 | Gateway 450ROG Notebook
My battery will not charge for my averatec laptop. The internal port seems loose and the external charger takes some wiggling to try to stay connected. Is the internal battery connection conneted to the...
I've never worked on this brand, but almost all laptops have the power jack soldered right to the system board. Flexing the power connector can break the solder connections and cause the problems you describe. If there hasn't been any damage to the system board, these connections can be resoldered. Getting to them can be a challenge as it means removing the system board to get at the solder side. But if you have soldering experience, patience, a small screwdriver, and some attention to detail, you can fix this.
The only trouble that may pop up is that sometimes electrical arcing occurs where the connections break, and may burn the circuit board. Sometimes the area can be cleaned and successfully repaired, sometimes it's too far gone. But it never hurts to try the repair. Good luck!
Jan 28, 2009 | Averatec (82-878011-01) Motherboard
Dell Latitude D505 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
