I HAVE AN OLD CAPEHART CONSOLE AND THE TURNTABLE DOES NOT SPIN THE MOTOR UNDERNEATH RUNS DO NOT SEE A BELT OR THE REMAINS OF ONE HOW CAN I TELL IF THIS UNIT EVEN USES A BELT
  • 397 Answers
SOURCE: Can't get the darn to work
Remove the drive belt and see if the turntable spins, if it does the drive motor is faulty, if it doesn't then (if this is a new turntable) it's possibly got a locking device to hold the turn table steady during shipping.
Posted on Sep 12, 2008
  • 4234 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
This particular unit uses an idler wheel to drive the table. Remove the platter and check the rubber wheel. It may be dirty, or just dry and slick. This part may need to be replaced or treated.
Dan
Posted on Dec 19, 2008
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
  • 69 Answers
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
Posted on Aug 08, 2009
  • 6 Answers
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
My turntable does not work on a audio component system
Is the motor on the turntable spinning - wiring misconnected?
If motor is running then th epower is not being transmitted to the platter by either a belt drive or a pulley drive.. The belt or pulley has to be replaced to restore the missing friction
Mar 14, 2015 | Audio Players & Recorders
Sep 12, 2008 | Sony PS-LX350H Turntable
BELT-DRIVE MANUAL TURNTABLE
5 years old and not sprinning is for every turntable bad, i'll never buy a technics which has been in a box for 12 years. I think since the lubrication of your cheap motor works fine, but if it never spins a part has run dry. Your belt can be broken, but then that you'll notice . It just can't be a lot , Did you check the output of your powersupply.....
You can check if the cable that runs to your switch is connected and otherwise you buy another motor, though i wouldn't spend a lot on it, since you buy them new for zero money with a better arm and motor.
Feb 16, 2015 | Project DEBUT III Turntable
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 01, 2009 | Technics SL-1210 Turntable
JVC turntable LA10
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Mar 16, 2008 | Audio Players & Recorders
JVC turntable--broken motor?
I just worked on a unit with the same problem. The spindle bearing will seize up if it is not oiled at least once a year. Take off the feet and split the top and bottom. Remove the three screws that hold on the spindle. Remove the E clip that holds on the gear. Put it in a vise and press off the gear and remove the shaft. Thoroghly clean off the shaft and the bearing. Lub with 3 in 1 oil and reassemble.
Sep 07, 2007 | Kenwood XD-A55 CD Shelf System
Speed Changes
Perhaps it's time to change the belt on your unit. If after you change the belt, you still have the same issue, then the problem might be with the motor itself. The motor itself is a relatively inexpensive part, around $20-30, and the labor should run in the 40min range - so you can get an idea of what it will cost. Hopefully it's an easy fix. Not sure where you could source the belt, but if you take off the old one, you should be able to match it up easily. Also, there should be a part number in the user manual, and instructions on ordering a replacement belt or at least a part number. FYI, belts generally run in the $5-15 range, and are user replaceable. Good Luck!
Aug 20, 2007 | Philips gemini TT-01 Turntable
223 people viewed this question
 Grubhead
Grubhead
