Question about HP Computers & Internet
Expansion bay on my tower will not open
The expansion bay on my HP 6750 tower will not open. I'm pretty sure it did when I first purchased it. Does anyone have any hints?
SOURCE: i have a emachine w5243
the expansion drive will open if you can hang a fingernail or something thin in the top of the door and pull. It only takes a gentle pull.
Posted on May 16, 2008
  • 13433 Answers
SOURCE: HP DV600dv Expansion Port 3
the expansion port is for a docking station. or a extender..
unlikely to turn the laptop into hdmi, well look into expansion docks and see what you find.
Most likely no.
Thanks,
Ekse
Posted on Feb 16, 2009
Dreamornaut
  • 55 Answers
SOURCE: I need a power supply compatible with Cooler
The Cooler Master RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified Crossfire ready 80 PLUS certified modular active PFC.
Cooler Master eXtreme power RS550-PCARE3-US 550W ATX12V V2.3 SLI ready CrossFire ready power supply.
Two models that should fit with that tower. Cheers!
Posted on Aug 20, 2009
SOURCE: my expansion bay will not
Try to open the lid above the button with your nail,you'll see a metal plating covering the inside of it.The expansion bay is to add another drive, like a Cd/Dvd drive. Just don't worry about it too much,when you ad the new drive,you can take the plating off.Whoever adds the drive will open it up,too
Posted on Jan 16, 2011
  • 11800 Answers
SOURCE: a power supply compatible with
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017
Posted on Jan 25, 2011
Corsair h50
The installation and use of cooling fans in PCs is pretty straightforward once you understand the airflow layout and mechanical assembly.
You need to learn the necessary skills to make sure you are setting up your fans to direct the air where it will do the most good, as well as how to choose (and mount) the correct fan(s) for your situation.
Computer fans are manufactured in five distinct varieties: case fans, expansion-slot fans, hard-drive coolers, CPU fans and external drive-bay fans.
With case fans, there are several physical sizes that are measured in millimeters.
Another measurement the manufacturer will provide is the CFM (Cubic Feet per Minute) the fan is rated for.
As a general rule, the smaller the fan in size and the higher the CFM rating, the more noise it will create.
Before you purchase additional fans, open your case to see what kind of fans can be added.
The fan size must match the size of the opening in the case to be at peak efficiency.
You will need to establish you have expansion slots available if you want to add an expansion slot-style fan.
It is crucial you establish a pathway for the air being moved inside your case to follow.
As an example, having all the fans blowing air from the outside of the case to the inside is not as efficient as having fans on the front of the case blowing cool air in while the fans located in the back of the case are sucking out hot air.
It is recommended the best practice is to position a case fan in the front bottom of your case (bringing in cold air) and at least one fan mounted midway up the rear of your case (expelling hot air).
If possible, use two fans in the back to expel the hot air as a lot of it is being introduced by the CPU cooling fan.
The mounting of case fans is done by using four course-thread screws usually provided with the fan.
These screws are self-tapping and will be inserted through the hole in the case wall created for a case-fan screw, then screwed into the case-fan body mounting hole.
Make sure you use all four screws to hold the fan securely.
The installation of an expansion slot fan can target specific areas where heat is generated.
When mounting one of these fans, make sure the expansion slot fan is not in direct competition with the fan mounted to a video card.
Having the expansion slot fan blowing directly into the video card's fan, which is trying to blow out air, will defeat both of the fans' purpose.
Hard-drive coolers usually mount to the circuit board side of the hard drive and work to keep it cool.
Because of the location of most hard drives, there is very little disturbance from the air that is released from the hard-drive cooler to the airflow pattern mentioned earlier.
External drive bay fans can provide an enormous amount if airflow, assuming there is an external drive bay open.
http://www.homepcbuilder.com/lessons/installation/lesson04/lesson04.html
Jul 28, 2013 | Video Game Consoles & Games
What power supply is compatible with a cool master CAC-T05-UW? ATX Mid Tower ATX, Micro ATX compatible form factor 2 External 5.25drive bays 2 External 3.5 drive bay 2 Internal 5.25 drive bays 7...
Hello vonii94,
Welcome, and thank you for using FixYa!
To answer your questions, the sky is the limit! :)
Any modern power supply you would purchase, as long as it is ATX Compatible, will fit this box.
I recommend at least a 750Watt so that you have growing (upgrading) room in the PC. Antec and Cooler Master make some nice ones.
www.newegg.com or www.tigerdirect.com
Have a great day!
Sep 12, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
My expansion bay will not open.
Oct 09, 2010 | HP Computers & Internet
Remove cd from hp pavilion hard drive expansion
Use a paperclip and push it in the little hole on the side.
Oct 25, 2009 | HP Computers & Internet
I need a power supply compatible with Cooler Master CAC-T05-UW. Features are ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 External 5.25'' drive bays, 2 External 3.5'' drive bay, 2 Internal...
Aug 19, 2009 | Computers & Internet
Blank screen when I turn on my N64
The blank screen is usually caused by a faulty connection.
If you are sure all of your cables and the expansion pack are installed correctly, try removing the pack and blowing on both the expansion bay and the expansion itself to knock any loose dust out.
If that doesn't help, check the expansion pack and then the the bay for damaged or bent pins. Check the game cart as well.
If everything appears undamaged, you may have a broken/defective expansion. See if you can get your money back and then try to find another one from a trustworthy retailer or friend.
Aug 09, 2009 | Nintendo 64 Console
I have a emachine w5243 tower the expansion drive won't open.push botton but still know
Mar 29, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
374 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
