Question about Cisco Catalyst 6513
Cat OS 6513 module deteced but not shown in show config
The module is detected in show module. but not show in show module
  • Yuriy Beznos
    Yuriy Beznos May 11, 2010
    Please rephrase your question.
    What module are you referring to?
    Problem Solver:
  • 7 Answers
I had this same problem on a switch a while ago. what version of CATos are you running on this switch. the blade you are using might not be upto date.
I had a 6506 with 10/100 modules/ upon installation of 10/100 with inline power the chasis would not detect it but would detect the board.
I updated the CATos version and it worked
Posted on Mar 18, 2008
Looses power after warm up
Is the check engine light on or are you showing any codes?
There are dozens of possible reasons for this. A common one is the O2 sensors, but this would likely show a code.
There is a lot of "stuff" that happens between cold start and normal temperature running, most of which is tied to sensors and what the feed to the Engine Control Module.
Most (but certainly not all) things that aren't right get detected by the ECM and generate a code that helps further identify the root cause. Even these codes can be a bit misleading. A Toyota code that says one needs to change the catalytic convertor can often be fixed by replacing the before cat, after cat, or both sensors and that is a lot cheaper than changing the cat. (most of the time shops will automatically change these sensors when they do replace a cat, otherwise the new cat doesn't fix the problem).
Oct 26, 2013 | 2001 Honda Civic
What is the sc 422 error on a RICOH AFICIO 6513?
SC422 PCC leak - Timing & Condition -
When the current leak is
detected for 2 seconds,
and the leak detection
started 1 second after the
PCC turned on. This leak
signal is monitored twice a
second. If it is detected
twice in a row, this SC is
displayed.
• PCC unit not properly
installed
• Broken corona wire
• Defective high voltage
supply board
(T1/PCC/BR)
• Defective I/O control
board
• Defective main control
board
Sep 02, 2011 | Ricoh 6513 Copier
Lancard drivers is not taken in redhat 5
every driver has to chose os so there is different driver for redhat operating system so please download drivers for redhat operating system
Oct 20, 2009 | Intel DG31PR Motherboard
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
Pen drive is not detected
Check your pendrive in other PC, if same problem is seen, then your pendrive is over. & if it is detected in other PC then, your PC needs to install new OS. This will fix error for your pendrvive
Apr 21, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
2000 ford winstar sel update to problem
i had asimiliar misfire on my 2000 windstar.the first thing to check is a broken valve spring by taking off the valve cover the other is a o2 sensor bank 2 i believe is the downstream.if not the valve spring then either the coil pack or thecontrol module. either way it is fairly inexspensive
Mar 02, 2009 | 2000 Ford Windstar
Failes to detect mp3player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 27, 2008 | Audio Players & Recorders
If you are using Windows 95, the player is not supported. If you are using Windows 2000 or XP, it will show the player as MTP player. If the MTP is not shown on My Computer, install the player as removable disk (use Device Manger, find the device connected, right-click on the player icon, and click Update Driver).
Sep 28, 2007 | Sony NW-E002 MP3 Player
Cisco Catalyst 6513 Logo
200 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
