Question about Hotpoint VBXR1090D Top Load Washer
Top agetator is not working what do i look for
Top agitator is not working what do i look for
  • 5,911 Answers
Are you sure your washer is a Hotpoint? I ask because the model number you have this question listed under has a single piece agitator with a fabric softener dispenser snapped on top of the center post. If you are having problems with the fabric softener not dispensing, you simply pop the cap off the center post and wash and rinse in some hot water to dissolve the fabric softener build up.
Now...if you have a split agitator design, such as the one on Whirlpool manufactured top loaders, you may have a worn agitator cam assembly or worn dogs.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you aren't sure, or have additional questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Posted on Jan 31, 2010
    Novelist:
  • 127 Answers
Well if the model number thats attached to this call is even close theres still 20 sub-models from ther. anyways your agitator sits upon a plastic drive bell, you can remove the agitator by pulling up sharply upon the agitator (sometimes a belt looped under the agitator provides a better grasping surface), then you can see and touch the drive bell, which is held in place by a 7/16th bolt.. that drive bell is indexed to the transmission drive shaft by splines that sometimes/often wear out allowing the agitator to spin sorta freely..
give that a shot and let me know..
have fun, and good luck,
ttfn
Washer does not agitate during wash or rinse cycle. I can push the center spindle to the side and it starts to agetate, but when I release the pressure it stops.
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topagitatorvideo.html this will walk you thru the proper inspecting and replacement of these parts. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 14, 2010 | Whirlpool LSQ9600L Top Load Washer
My simson encore 703 when it starts to agetate whenit turns to the right it turns quickly and the clothes get tangled around the agitator
result from a simple broken pin, which causes the tub to spin whenever the motor runs, even while agitating. Call to find out how to fix this common problem – it’s very inexpensive.
Jun 23, 2008 | Washing Machines
Maytag performa PAVT234AWW top load washer. The washer fills and spins fine. But when it is the wash cycle, the agitator makes a grinding noise and kind of vibrates in place. Is this something that can...
sounds to me like you have a bad transmission
what happens when you take the agetator off
does it still make the noise or does it go away?
if it goes away when you take the agetator off then you have a bad agetator
Aug 24, 2010 | Maytag Washing Machines
Kenmore stackable , agetator cone does not move
If this is a Whirlpool manufactured top loader (such as Kenmore), the problem may be a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. The agitator parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 10, 2010 | Washing Machines
Lower half of my Knmore Washer does not agitate
do you mean the top does not agetate but the bottom does?
replace your agetator dogs
part number 80040
you need to take the agetator off nad seperate the bottom from the top you will see your agetator dogs.
Feb 15, 2010 | Kenmore 24032\24036 Top Load Washer
When agetating th washer makes a cicking noise?
It is your clutch that is on the motor is bad. Your clutch controls the motoro in order for it spin or agitate.
Dec 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitation issue
So you say the agetator is moveing or when the clothes go up and down does it stay in place and make a rattcheting sound. if it is not moving the clothes up and down you need new agetator dogs. pop the cap off the top of the agetator some have a plastic cap that you can poull off to get to the 1/2 inch screw inside. some don't if you can see the bolt around the edges of the inside of the agetator you will see groove marks and when you turn the agetator by have you will see 4 plastic tear drop looking thing that grab the grooves of the agetator these tear drop things get stripped over time. replace them and this should solve your problem. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
ON SPIN CYCLE AGITATOR MAKE A LOUD BANGING SOUND
So while you are holding the agetator is it ripping your hands? or is the agetator just sitting there? If the agetator is just sitting there you probably have bad agetator dogs. I would remove the fabric softner or cap whichever you have. under the cap you will see grooves in the agetator down low. When you manually turn the agetator you should see 4 tear drops that grab the grooves if you do not see this you have bad dogs. Very simple. This usually is the cause for the grinding noise that you are hearing. Please let me know if this works for you //eg
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator noise in maytag performa machine
The noise in your washer tub could be caused by some object lodged under the agetator. Lift off agetator and check. Or somthing could have gotten into the sump tub. this could be a major job as you would have to remove the complete inner tub assy. One other problem I can think of it could be worn tub bearings. If the washer is 10 or 15 years old I would replace it,
ljtomega
Dec 03, 2008 | Maytag Performa PAV2200
Hotpoint VBXR1090D Top Load Washer Logo
189 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
