Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Service part number for washer arm and screen.
Service part numbers for washer arm and screen.
  • Fisher and P... Master
  • 3,247 Answers
525014 SPRAY ARM ASSY
I suppose the screen you mention is the large round disc that is called the filter plate
527018 FILTER PLATE ASSY WS
Hope these are parts number that you asked for.
Posted on Feb 05, 2010
GE Spacemaker washer WSXH208A
WWW.appliancepartspros.com have schematic diagrams, part numbers and price for the above washing machine.
Mar 13, 2014 | GE Washing Machines
Savage arms corporation
Savage Arms is no longer able to access historical information on older Savage, Stevens, or Fox firearms. This information may be available through John Callahan who is an independent arms historian and is not an employee of Savage Arms. Mr. Callahan does not provide parts, gun smith services or offer a locator service for firearms or parts. Please send a detailed letter with:
-Your name and address
-A phone number where you can be contacted if necessary
-The model and/or serial number if available
-Any other pertinent information
Mr. Callahan will respond with a letter detailing his services. Send the
letter to:
John Callahan
P.O. Box 82 Southampton, MA 01073
Feb 27, 2014 | Optics
What is the customer service number for the six month warranty that comes with the tablet?
i dont think so...
maybe if factory deffect that was covered the warranty.
May 08, 2013 | Tablets & eReaders
What does the control arm on the front left driver side supposed to look like fully assembled
Hello! First diagram is the lower...Second is the upper..Guru...saailer
LOWER IDENTIFICATION:
Item
Part Number Description 1
5495 Stabilizer Bar Link Bolt and Bushing Assembly 2
18A192 Nut, Washer and Bushing Assembly 3
808264 Bolt 4
5005 Frame 5
5B326 Torsion Bar (LH) 6
5B327 Torsion Bar (RH) 7
620481 Nut 8
5C491 Nut and Washer 9
3079 Front Suspension Lower Arm (LH) 10
3078 Front Suspension Lower Arm (RH) 11
3A130 Tie Rod End 12
808166 Nut 13
808167 Nut 14
5K483 Front Stabilizer Bar Link 15
5482 Front Stabilizer Bar 16
5484 Front Stabilizer Bar Bushing 17
3B353 Front Stabilizer Retainer 18
N807396-S100 Bolt A
- Tighten to 40-55 Nm
(30-40 Lb-Ft) B
- Tighten to 150-200 Nm (111-148 Lb-Ft) C
- Tighten to 21-29 Nm
(15-21 Lb-Ft)
UPPER IDENTIFICATION:
Item Part Number Description 1 3C156 Damper Assembly (RH) 2 805348 Nut and Washer 3 - Shock Absorber Insulator
(Part of 18198) 4 3C157 Damper Assembly (LH) 5 3020 Front Suspension Bumper 6 3083 Front Suspension Upper Arm Assembly A - Tighten to 34-47 Nm
(25-35 Lb-Ft)
LOWER DIAGRAM FOLLOWED BY UPPER:
Feb 12, 2012 | 1996 Ford Explorer
Washer is not getting dishes very clean, is there a filter or something I can clean
Hi and welcome to FixYa, I am Kelly.
Dishes not getting clean is caused by either a restricted drain, (usually the problem) or larger than usual particulate under the lower wash arm tower.
The restricted drain can manifest itself:
- At the pump outlet, (remove hose and inspect drain port)
- At the air gap at the sink (remove cover by lifting straight up then unscrew the inner cap nut and remove the particulate) NOTE the installed position of the upper cap under the net as it will only go back together in one position)
- At the Air Gap outlet hose connection (remove hose and inspect plastic tubing)
- At the sink connection. This can be either a direct plumbing connection or a garbabge disposal connection. (remove the hose and inpect drain connection.
As far as the lower wash arm tower
- Remove the lower wash arm.... NOTE the stack up of parts... it only goes together one way!!!!
- Remove the lower wash arm tower screws
- Lift off the lower wash arm tower and clean the screen area.
- Remove the screen and check in the pump impeller area for a broken inpeller or damaged pump housing.
I really need the long model number if you need further assistance. The model number will look like this 220.13599000 but the numbers could be something much different.
Thanks for choosing FixYa
Kelly
Nov 25, 2010 | Kenmore 13599 / 13594 / 13592 Built-in...
When the washer spins it makes a banging noise and the plastic around the tub shaves off
Thank you! We took our Duet 9150 apart and found that ALL THREE support arms were cracked. Same problem with shredded front tub also. My washer is a little over 7 years old. I called Whirlpool at the above number (you can't get "warranty service" but the parts service lady transferred me to the warranty dept). They were most helpful, and are shipping me both the metal tub AND the plastic which the metal destroyed, free of charge. Apparently your experience has shown them they have a problem with this...or I got a more helpful service agent!
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I access the inlet water valve to change it in a Kenmore 110.82880100?
First, see the Sears Parts / diagrams for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.82880100&pathTaken=partSearch
Look at the section on the Rear Panel Parts #27 and you should see how the inlet valve connects.
Then see the following for how to release the console and pull the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=894dfbbe68fb2a6a2d34fbf0abb0cf24
Finally, see the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Armed with those three references, you should easily be able to get to and replace the valve.
As an aside, On the Sears site, when it references a Manufacturer Authorized Substitute part number, the Number is a Whirlpool number.
Jun 23, 2010 | Kenmore Washing Machines
Upper arm on my model number gld225crdb3
Peace ,
This was listed at the washer site!
But I see that you have a gallery dishwasher from Frigidaire!
If the arm came off then there is a worn or broken part!
Better call service !
If I was there for hands on inspection then I could determine what
part you may have that malfunctioned but they vary.
Bless You,
please rate me on this site before signing off
Sep 01, 2008 | Frigidaire ATF6000ES Front Load Washer
How is teh washer arm secured to the dishwasher?
There should be a screw under the telescopic part of teh arm that holds the arm onto teh dishwasher.
Aug 06, 2008 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
56 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
