Can I add a wireless card to a Toshiba Satellite 5505 S504?
  • Jesse Lohse May 11, 2010
    You can purchase a PCMCIA wireless adapter or a USB WiFi adapter. See images below. You can buy these at Walmart, Best Buy, or any of your favorite electronics stores or websites. They cost between 30 to 60 dollars. I have included some pictures to help you. USB WiFi Adapter PCMCIA WiFi Card Good Luck, NOLA Tech
  • Bruce Hathcock May 11, 2010
    If it has a usb port you can add a USB wireless card however are you looking for network or a wireless mouse?
    President:
  • 2,047 Answers
Yes you can add one but you will need wireless driver for it too....so you download dat from the internet....although it is supposed to come with a wireless lan inbuilt
Posted on Jan 31, 2010
I have crackle in the speakers on my Toshiba PS500 Satellite.
Hi Check the cables are correctly plugged and the sound card drivers are correctly installed. It might be the speakers have been damaged.
Mar 05, 2011 | Toshiba Satellite 5005-S504 Notebook
My satellite 5505-S504 seems to heat up and shut down. I can hear the fan but the bottom of case seems to get to hot. It will not boot up completely. It boots to the point that the windows xp logo shows,...
A lot of Toshiba laptops had overheat problems. Buy a can of air and blow out your air vents real good. One in the back is a heat sink and they accumulate dust and will start heating up. You can buy the air at any electronics or computer store or if you have an air compressor you can use that, the can air is dry.
Dec 11, 2010 | Toshiba Satellite 5005-S504 Notebook
Muchas gracias por la oportunidad, es una Toshiba Satellite 5005-S504 de minguna manera entra a la Bios, Qué puedo hacer?
si puedes leer ingles este sitio te servira mucho. te dice como resetear el BIOS. y sitienes una password como resetearla en tu toshiba.
http://www.tech-faq.com/reset-bios-password.html
espero haberte ayudado en algo.
Dec 09, 2010 | Toshiba Satellite 5005-S504 Notebook
How to remove cd drive Toshiba 5005-S504 laptop
If you remove the memory card cover, there is a screw under it that holds the DVD drive in. Remove the screw and the drive will slide out.
Hope this helps.
Nov 16, 2010 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
I can not find the model number on a toshiba satelite, on the back it says the seriel number but I am not sure of the model number. I am trying to find out if it is wireless or not.
If your laptop has a built-in wireless card and the driver was installed then the easiest way to check is to go to the Device Manager and check Network Adapters to see if you have a wireless adapter, this will confirm if you have one or not.
Jun 28, 2009 | Toshiba Satellite 5005-S504 Notebook
I have an old Toshiba 5005-S504 - want wireless connection
I looked at the specs of the laptop and it doesnt seem to have a inbuilt wireless card. Here is where I looked and if this is indeed the laptop you have, then it doesnt have a wireless card built it, http://www.pcworld.com/reviews/product/6781/review/satellite_5005s504.html
Since it has 3 USB ports, you can use one of those ports to add a wireless card. Netgear has a card.. More detials of this card are in this link. http://www.netgear.com/Products/Adapters/WirelessGAdapters/WG111.aspx
So, if you plug the WG111 in and install it, it should help work. Netgear has free 90 days support and they can help you install. Not complicated at all,if you read the manual before calling the customer.
Hope this helps Ranjit ranjit@supportminds.com
Jun 16, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 Secure Digital Card Slot problem
Hi there
Take a close look inside the card slot (you may need a torch/flashlight) look to see if any of the brass pins are bent or out of position, if they are use a very small flat head screwdriver to gently push them back into place.
If all looks fine with the slot and there are no foreign objects inside your card maybe faulty.
Also i suggest the you check the drivers are installed, check this in device manager.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Toshiba Satellite 5005-S504 Notebook
Moitor extremely dim; how do I get the external monitor to start
Ok friend this equipment unlike the rest has a card of video piggy back that is inserted in the system board, according to the symptoms of the fault that you describe, this one resides in the card of video which you must replace to be able to solve your problem. Good luck.
Dec 16, 2008 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
