Question about Hifonics OLYMPUS OLM1612 Car Subwoofer
I have 2 kenwood 3011 400 watts rms and 12oowatts peak power each 1 is blown and wonderin about upgrading 2 the Hifonic Olympus OLM1612 would this be a good upgrade even thought i only a 400 watt kicker amp
    Novelist:
  • 149 Answers
Yea for sure thats a good upgrade. You shouldnt havebeen able to blow the kenwoods with 400 watts though-meaning that they probably blew from distortion which causes heat(fast) Check your gain on the amp start it out at 1/4 gain and turn up your deck to the point where you can hear distortion from your mids and highs or to the maximum level that you listen to your music at. If you're jamming out at a level that is causing distortion then you will be sending a distorted signal to the amp as well. The amp then amplifies the distorted signal through the subs which overheat and blow. So find the distortion spot and then turn it down just a little bit till it clears up your sound-then adjust your gain on the amp up slowly until you cant hear it getting any louder. Once you have done that you have reached the limit of CLEAN power that you are going to get.Thats where you want to keep it. Watch the bass boost too if you have the bass up on the deck and then crank up the bass boost on the amp it really f's up the signal too. Good luck
Posted on Jan 31, 2010
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
Watts rms?
It is the root mean square (abbreviated RMS or rms), roughly 0.707 of the peak wattage of an AC source. Crutchfield lists it at >power range: 2-110 watts RMS (450 watts peak power)
Sep 16, 2013 | Kenwood KFC-6986 Coaxial Car Speaker
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
Apr 08, 2011 | Kenwood KAC-9103D Car Audio Amplifier
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
I dont have any cosmetic problems with my subs .. but i have 4, 12 inch hifonics olympian subs in one sealed box. and i cant find any specs on them at all.. do you know the watts and rms wattage and how...
look on the bottom of subwoofer should say like olm2412 olm1612 olympus the 1612 is the rms and speaker size 2412 is 2400 rms and the 12 stands for 12 inch subwoofer.i think thair is only 2 modles . also u have 4 u would need a 10,000 rms amp if thay are the olm2412s or 6,000 rms amp to push 4 olm1612. as far as box building info i think you should call maxxsonnics. 847-540-7700 talk to mike
Mar 03, 2010 | Hifonics W-124 Olympian 12" Subwoofer Car...
Mtx audio 4252 amplifier
Hello freshman_fox,
63 watts X 2 @ 4-ohms.
125 watts X 2 @ 2-ohms
250 watts X 1 @ 4-ohms bridged
Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
You can download the manual from here. Hope this helps.
Jul 10, 2009 | Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Hifonics OLYMPUS OLM1612 Car Subwoofer Logo
76 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
