Question about StarTech.com StarView SV211K 2-port KVM Switch
I have a 1989 f150 turns slowly when starting. I checked batt ok replaced ing switch key switch turns slowly but when I jump start it it starts right up cuold syarter be bad replaced solenoid on fender
  • 70 Answers
It could be a bad earth on either solenoid or starter i had this with a ford capri about 8 years ago it would bump start and jump start but not start of the key once it had started once it would start again all day but after standing over nite no start i cleaned all earth connections and starter connections and it wos ok so i would try this failing this try new start solenoid or starter
Posted on Apr 01, 2010
2007 Dodge Caravan won't start.Batt. is good, all lights work, Turn key, solenoid clicks and stops, all gauge needles slowly move to max., and return to min. No codes displayed.
When you try to start it do the lights dim way low, have you been able to start it with a jump from another vehicle, unfortunately, chances are the starter needs to be replaced. How many miles does it have?
Feb 09, 2013 | 2007 Dodge Grand Caravan SXT Minivan
2006 Mercedes-Benz C230, the starter turns very slowly.
The batt voltage is to low try jumping it with jumper cables if it starts you need a battery
Dec 27, 2012 | Mercedes-Benz Vehicle Parts & Accessories
96 vf750 magna. Turn key, no head light no starter buttton. Will not jump start. New battery and fuses ok. Popping 10amp start/ing fuse when jumping. Has high beam no low.
Replace the starter button. Unfortunately this means replacing the whole right switch assembly. You can activate the starter by jumping the two terminals on the starter solenoid. When jumping a motorcycle from a car battery make sure the car is not running, it can damage the cycles electrical system. You may have burned out the low beam on the headlight bulb. The bulb should be replaceable and is easily removed from the back of the head light glass. The head light bulb can be purchased at most automotive stores.
Sep 17, 2011 | 1996 Honda VF 750 C Magna
I cant get my truck started it turns over but wont start i think it might be the connection to the battery how do i change the battery cables
if it turns over but will not start, its either theft locked or the fuel pump is bad . start by checking the fuses in the fuse box under the hood .. if there is a problem like it was jumped with the cables backward it will blow one of the 40 or 50 amp fused in the fuse box, if those are ok see if the theft light is flasing, some 98s do have trasponder keys the can loose program. if the theft light is no on and the fuses are good check the inertia switch it will shut off fuel to the engine. its located in the right front kick panel ,remove the kick panel and make sure its pushed, if all that is ok and you still think its the cables , have some one crank the engine while you wiggle the cables if it starts then and you do need to replace the cable the easyest way is to buy the cable extesions at the parts house, that is a cable end with a piece of batt, wire that has a screw fastener ,just cut the old batt, cables of strip the ends and insert into the new fastner and tighten the screw
Dec 16, 2010 | 1998 Ford F150 Regular Cab
98 Ford F150 4.2 Liter Engine will not crank keeps blowing fuse #21 (15amp) as soon as I turn the ignition key. Was running fine just stopped to gas up and it wouldn't crank. Jumped the posts on the...
Sounds like there's a grounded wire somewhere between the ignition switch and the solenoid. When you bypass the switch with the screwdriver you don't ground out the line, but with the switch the ground shorts the circuit, blows the fuse, and then won't start the engine.
Apr 18, 2010 | 1998 Ford F150 Regular Cab
My 1997 dodge caravan won't start. has no power to starter wire or to engine. battery ok stater ok switch ok fuses and relays ok
there is an interrupt switch, called neutral safety switch. When it fails or goes out of adjustment, no start, and essentially no protest or indication. Try foot on brake, shift to neutral, turn key to start and slowly move shifter out of nuetral in each direction. If starter actuates, look into switch adjustment.
Sep 06, 2009 | 1998 Dodge Caravan
F150 wont start
What year is it exactly. Is the column square with plastic covers or round.
Jun 13, 2009 | 1989 Ford F 150
2004 r1 it won't start need help
Id Smack The Started With A Hammer Cause That Would Be Your Clicking Sound. But Yeah Id Start With The Fuses Other Wise.
Jan 12, 2009 | 2005 Yamaha YZF-R1
I have a 1989 F150 4x4 that won't start. I've replaced the ignition switch, a broken ignition switch actuator, and the EEC Power Relay -- it still won't start. I have full power for radio, headlights, and...
Try jumping the starter solenoid (between small terminal and the positive side) to see if it starts, if so replace selenoid; if not check to see if small wire is hot(someone will havfto hold the key in start position for you); not hot got broken or blown fuse some where.
Nov 29, 2008 | 1989 Ford F 150
StarTech.com StarView SV211K 2-port KVM Switch Logo
64 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
