Question about M-Audio Studiophile BX8a Speaker
Where can I buy replacement speakers (tweeter and the 8 inch) for a bx8? I can do the rrepair myself
    President:
  • 2,047 Answers
Depends on where you are located...try online at audiostore.com, amazon or ebay...otherwise chect the nearest electronics store
Posted on Jan 31, 2010
How to take the big speaker out of a studiophile BX8 speaker
As you can see, there are 8 screws holding the woofer in. Remove them, lift the speaker up, but before you disconnect it....Mark + and - onto the wires...red + and black -. .http://i46.tinypic.com/14l3j0z.jpg
Aug 18, 2014 | M-Audio Studiophile BX8 Main / Stereo...
How to remove tweeters maudio bx8 speakers
Remove the backplate and the wires are often hold togeter with a tiedrap, so you need a long , how do you call it in english:) , sciccoskind tool or you can try to unplug, the plugs between the powerunit/ amplifier and you speakers . I'm busy rebuildimg m3-8 from m-audio, cause of some where cheap amp/powerunit and did it by hand and i have large hand, but put some tape around the backplatesurrounding for scratches.
And if you have them loose you can remove them.... but why?
Do you think you just can replace them for other once, think again
Jul 10, 2014 | M-Audio Studiophile BX8 Main / Stereo...
Hey.. I just bought a Bx8 studiophille.. Unfortunately I got cheated.. One of the speakers tweeter is not working.. Can you give me a solution.. Where can I get it replace??
How sure are you that't you tweeter and not a contact cable or, sunce they use cheap xhinese capacitors on the m-audio, just a capacitor has dead. Don't buy a tweeter, since they very often die and check the inputs , especially TRS amd rca and unscrew the the backplate and you'll notice that the cables and connectors used are cheapio. So it worth to check the pcb,s if you see broken caps. Which wouldn't surprise me , since their cheap once. And before buy another tweeter, first try it out on another small amplifier, to see if it works. Buying a new ine is the last fase, they ask high prices for a 10 dollar unit. Where did you buy it and how old is the unit?
Greetings richard
May 09, 2014 | M-Audio Audio Players & Recorders
Tweeter not working??
Since it sometimes gices a sound, and i know the problem when it's not put it totally and does it. I want to know what it does with rca cables, trs cables and xlr cables and what it does and what ut doesn't. The connection inside in the trs and on one pcb , connected to your main pcb with three cables and it could be that one is not connected right. First of all. it's in the Netherland minimal twp years quarantee, since you may expect the speakers go allong min 2 years. Check you consumerrights, before start screwing.
And just measure your cables with a simple ohm meter or buy for 25 euro a cable meter....very easy and the costs ain't a thing.
gr. richard.... With all the cheap speakers and cheap connectors it might just as well beinig the connector inside, i hate them and replace them.
Jul 13, 2013 | M-Audio Studiophile BX8 Main / Stereo...
Very little output from tweeters Samson Resolv A6
same issue here, my 6 inch woofer is good but the tweeter is not producing sound, i opened the box myself, theres not signal going to my tweeter, how can i check to see if its a wiring or other issues to diagnose myself? heres some pics
Aug 10, 2012 | Audio Players & Recorders
I have a Makita BMR100 radio. Stock speakers are 3.25" 8 ohm with an 8 watt 8 ohm amplifier. I replaced speakers with better 4" 4 ohm but they're not really compatible with an 8 ohm amp. I...
Buy an 8 ohm speaker and wire it in series-parallel look up images of of combination series-parallel wiring this allows wiring all speakers and keeping the 8 ohm loaf on the amplifier. Should get more linear volume between speakers. Not sure if replacement is worth it, those speakers are pretty good and work well with rain and jobsite conditions. I am planning to install some 8 ohm half inch tweeters on my Makita radio and using the series parallel wiring. Plead note series-parallel wiring is not series wiring or parallel wiring. It is s totally different way of wiring it that uses both names.
Jun 02, 2011 | Makita BMR100 Radio
Cuoul i replace the tweeter with any 1 inch tweeter other than acoustic research?
Providing you match the power and ohm rating of the acoustic tweeter yes. You could of course have an higher rms/watts rating than the original, but not lower. The ohm though must be the same. The only thing that might happen is that it might sound different to the other speaker, as the tweeter sound quality could be better or worse than the acoustic. Of course you could buy two and replace the other speaker one too!
Feb 14, 2010 | Acoustic Research AR PS2262 Main / Stereo...
Purchased used m audio w/o connect cables for cpu
The BX8's take either a TRS or XLR inputs only. from a laptop, you can get a 1/8" stereo to 1/4" l/r mono splitter cable at radio shack that will plug into the back. then just plug up and you will be good to go for about $10.
serously, though, you should save up and buy a studio level firewire or usb card like the presonus inspire and use that to connect. for 200 bucks more spent, you would have much better quality recordings and playbacks that are matched and line level.
BOO-YA!!!
Dec 22, 2008 | M-Audio Studiophile BX8 Main / Stereo...
Open Questions:
See all M-Audio Studiophile BX8a Speaker Questions
M-Audio Studiophile BX8a Speaker Logo
564 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
