Question about Biostar G31-M7 TE Motherboard
G31-7 TE motherboard gives one long beep, wont post to hard drive, stuck in a loop keeps rebooting
  • 11,800 Answers
One long beep means that something is wrong with the memory. Try using another one.
Posted on Jan 31, 2010
I'm stuck in boot loop with a new configuration. Any Ideas other the reseting the CMOS to get out of the boot loop?
power supply? check and re-check connections (hard drive, cpu power cord, main connection to motherboard).
its your memory listed under the "memory support list" of your motherboard manufacturer?.
if not listed, contact the manufacturer (motherboard and memory) to make sure that they work together.
if none of these works, you have a bad motherboard. Good Luck
Jul 29, 2014 | Gigabyte GA-B85M-HD3 - Intel B85 Chipset...
Won't post
if your computer wont boot and is not giving the post noise
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 06, 2011 | ASUS P4S800-MX Motherboard
After opening my pc up to add a new hard drive, which i've sinced completely removed, my pc wont finish booting anymore. The gigabyte logo screen is displayed when i turn it on, but the post screen never...
There should be an on board speaker remove new h/drive boot should post ok and give no boot device error make sure new drive is set for master on jumpers select auto detect h/drive in cmos if detects save reboot should work ok good luck!
Jan 08, 2011 | Gigabyte GA-EP45-UD3R Motherboard
My IBM R32 laptop used to work ok, but now when I swtich it on, the battery light comes on & I can hear the fan working but the computer doesnt beep & load. I've switched it on & off, taken out...
With no beep codes to diagnose from, I'd say everything points to a motherboard issue. But before we go with that as the issue you must ensure its not a memory or hard drive issue.
First you must always make sure its off with the battery out before you touch any components such as memory or hard drives.
Take all the memory out of the laptop (under one of the plastic covers on the bottom) and then try turning it on, if you get beeps now then you know it has faulty memory. If you have more than one stick of memory then try with one then the other and in different slots.
Also try booting without the hard drive in, see what happens then.
Finally if after all this you realise it is a motherboard issue then you'll need specialist help to fix it. Use a company that charges fairly (should be around £55+vat for a simple motherboard issue) and also ensure they operate on a no-fix no-fee and give you 3 months warranty.
Oct 29, 2010 | Computers & Internet
Computer wont recognize hard drive and drive keeps clicking
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered sucksion vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
hope this helps good luck
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 13, 2010 | SimpleTech SimpleDrive 250 GB External USB...
I have a foxconn P4M800P7MA-RS2 motherboard and it keeps rebooting . It does the POST then reboots.I've just upgraded the OS from XP to Win 7 x86 and it still reboots.Any help would be gr8ly appreciated....
good luck
Sep 07, 2010 | EliteGroup P4M800-M7 Motherboard
Hp nx6110, stays in a boot-up loop
Hi, If you are sure that it's not overheating, then it could be the hard drive.
A boot up loop is an indication that the boot up sector on the hard drive is corrupt and broken. The hard drive tries to find this boot sector to boot up your computer but it can't. It keeps trying to find it again and again and again and keeps looping. Hank
Jul 23, 2010 | HP Compaq Motherboard
I've been building computers since 1992. Never saw this. My EVGA MB is in a BIOS loop. Boot .. beep .. EVGA Splash ... -Reboot automatically- Beep ... EVGA Spash ... -Reboot automatically. It's like a...
Turn the computer off.
Hold DOWN the "any" key.
Turn the computer on.
When you see "keyboard error. Press Fxx to enter BIOS SETUP", RELEASE the "any" key, and press the 'Fxx' key.
While in setup, change the boot-order to "floppy-first".
Then, everytime that you boot, your motherboard will "grind" the 3.5-inch disk, looking for a boot-sector.
If it DOES "grind", then BIOS-loading has completed, and there's something wrong with the boot-sector on either the CD-ROM or the disk-drive, i.e., Windows "crashes" during startup, and reboots itself.
Or, press F8 when you think that your computer is booting from the disk-drive, to enter the "Windows boot menu". Try "Boot In Safe Mode".
Feb 03, 2010 | Evga MB 115-K8-NF33-AX NF3-250 754...
Carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
System wont boot
i would slave the drive into another system revmove the data off it that i want to keep and then repartishion the drive and do a fresh install.
regards, daniel
Jan 12, 2009 | Abit IC7-G Motherboard
Biostar G31-M7 TE Motherboard Logo
250 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
