January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. Started fill on new cycle for a few seconds, water immediately started leaking. (Temperatures are about 12 degrees F outside. Washer is inside but I didn?t know if this could have an affect.) Cardboard cover over engine is partially wet. I don?t see any leakage from visible hoses. Photos below.
  • Washing Mach... Master
  • 2,669 Answers
Is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Posted on Jan 31, 2010
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore model 22642 top loading washer leaks somewhere from the bottom. I turned it over and couldn't see any obvious wet spots. All hoses are secure.
follow your drain line back into the bottom of the machine, there will be a box like plastic part that it hooks up to. I have had the plastic split causing it to leak during the draining cycle.
Dec 30, 2009 | Kenmore 22642 Top Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
How do I remove the cabinet from mt Kenmore front load washer. It is leaking during the wash cycle.
Screws along the bottom of the front lower panel. This will get access to find the leak. If it is up high the top comes off with 3 screws at the back top edge and slide forward.
Eric
Jun 26, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 80 series. Leaking from front under washer. Can hear standing water under agitator/basin
Usually with this situation its a pump leaking, does it leak mostly during use.if you lean appliance back, should be able to take a peak underneath at pump. will just need to be replaced if leaking.
Jun 08, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series
check for corrosion or cracks on the outer tub.that might be the only problem.good luck.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
