Question about Fire Magic FireMagic Grill
Can I paint a natural gas line to my grill? It is exposed on the house and I want to paint it.
  • 105 Answers
Yes, but it has to be painted yellow or red.
Posted on Jan 31, 2010
The igniter connection does not have the white cover to the side burner so part of the igniter metal is exposed. When I look at other grills, there is a white couplilng type piece so the igniter wire
It'll be fine...A tiny explosion happens anyway when a grill is lit.. Its just a ceramic fitted piece... Its ok...you can still grill..;-) if you replace you'll have to replace the whole ignitor.Have fun grilling....
Nov 20, 2012 | Grilling
I have a weber genesis grill. It did not heat up above 425 degrees at first and now it does not go above 300. This is with the searer on as well. Does this make sense to you? It is hooked up to a...
Was your grill originally set up for Natural Gas or did to convert it from Propane to Natural Gas? If so, where did you get the conversion kit? It may have been missing some vital parts.
If it was not a conversion, did the grill come with a natural gas regulator already installed?
Please advise... Thanks
Jul 18, 2011 | Weber Genesis Silver B Grill
Hi there, I have a Weber Q 300 Natural Gas. I have an outdoor gas outlet which have been capped at the end. I don't know how to connect it to my Weber. Do I need a gas fitter to come out? Please help.
Yes, you will need a gas fitter or gas technician to complete the hookup, because the gas line has been capped and you can be sure whether or not it's still an active line. In addition, you will also need (if you don't have it already) a 12' long, rubber, quick disconnect hose the runs from the pipe to the grill (this is a Code Requirement), as well as a gas line line shutoff valve on the end of that exposed pipe, as well as all the necessary pipe fittings.
Hope this helped you. Please let me know and Happy Grilling!!
May 16, 2011 | Weber Q300 Grill
Grill is 6 yrs old, natural gas hard line to house burners have only very low flame (really low) do I need to replace burners or valves? if so what does it take?
Before you start replacing parts, let's try trouble shooting the problem, by asking a couple of questions.
Have you checked the gas line shutoff valve, on the gas line from the house to the grill, to make sure it's fully open?
When was the last time you thoroughly cleaned the grill (i.e. Removed and cleaned the burners, the venturi valves & the burner orifices) ?
If you answered NO, to both or either one of the above questions, that's where you need to start.
If you no longer have the Owners Manual for your grill, please advise me, who the manufacturer is and the correct model number . I may be able to provide you with one. Even if you end up needing parts, you will need the Owners Manual to get the correct part numbers.
Hope this helped in solving your grill problem. Please let me know.
Apr 15, 2011 | Viking DVGBQ532-3RTL (LP) All-in-One Grill...
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
Natural gas grill needed to convert to propane
You would need to do the old crank down and flip routine. Crank down all spuds, open shutters all the way and flip the regulator nut to the LP position.
I found an interesting video on youtube which features gas stove conversion. Gas range conversion is basically the same.
Mar 07, 2010 | Weber Genesis Silver B Grill
Unused natural gas piping
Check with your fire department inspectors, or your gas company. Every State has different codes.
Feb 19, 2010 | Weber Genesis Silver B Grill
Uniflame gbc820w propane to natural gas adapter question
Most major hardware stores that sell grills have a universal conversion quick connect hose and gas line adapter fitting.  That.. you can probably handle.   Next you need to install a quick connect adapter from the house gas line or meter (unless one is already there for you).  Otherwise you may want to call your local gas company or fireplace/grill store to send someone out.    Last all LP to NG conversions require the orifices on the back of your grill's valves to be changed to larger holes.  (LP has more pressure thus small holes and NG must be larger.)  The trick is getting the precise numbered drill bit diameter(45-55) for your particular grill.  You can look on your manufacturers web site to provide this info.  Often times they can sell you a new set of orifices, predrilled, to the exact diameter for conversion.  Drilling out orifices is usually cheaper and pretty easy if you know where to find the bits (internet or specialty tool store).   Sometimes your local gas company or fireplace/grill shop will provide this service as well. Hope this helps, and good luck.
Mar 28, 2009 | Grilling
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Connecting to natural gas line
The city where I live requires a licensed plumber to do this. So I guess my problem is solved.
Jul 25, 2008 | Ducane Affinity 3100
Fire Magic FireMagic Grill Logo
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
