Question about Bushnell NorthStar 78-8890 (300 x 90mm) Telescope
After i choose the location closest to me and tell it what star to look for even if i know the tar is overhead it goes through a sequence of movements then ends up pointing at the ground
    Genius:
  • 1,027 Answers
Check the clock setting; it needs the correct time and date, as well as your location.
Posted on Jan 31, 2010
I would like to know the torque sequence on an intake manifold for a 2000 Saturn 1.9 liter double overhead cam
22 Foot pounds on the nuts/bolts
The sequence is an "X" pattern radiating outward from the center in two tightening passes.
Feb 24, 2017 | Saturn Cars & Trucks
We have a 2013 Transit 100T260 , Oil light is staying on even though the oil level is topped up ?
My vehicle has a reset sequence ,Tells me when I should change oil,and only goes off after I reset it.It's pain I know.You will find instructions in your owners manual.It will have a series of buttons you must push in a certain sequence then all will be normal.If you punch it into YouTube there are a few videos that will demo for you.Bonne chance.
Feb 25, 2015 | Cars & Trucks
What may be the problem and solution when you are installing any application download and you are told that the jar files did not match?
The binary edition of Ant is shipped with 3 different compression formats:
  1. .zip - Recommended compression format for Windows, can also be used on other platforms. Supported by many programs and some operating systems natively.
  2. .tar.gz - Uses the tar program to gather files together, and gzip to compress and uncompress.
  3. .tar.bz2 - Uses the tar program to gather files together, and bzip2 to compress and uncompress..
Choose the format that is best supported for your platform.
F150 parts.
May 27, 2012 | Nokia Cell Phones
Could you tell me the cylinderhead bolt torque for a 2003 mazda protege 2.0 litre engine with dual overhead cam and no turbo
First torque them in sequence to 13-16 ft.lbs.then in sequence to 85-95 degrees next do the same thing again torque to 85-95 degrees.
Jan 27, 2012 | Mazda Protege Cars & Trucks
2008 yamaha raider... wheres the fuse box located and is it easily acsisable
Look here for a manual. Choose the closest one and it will do.
http://www.repairmanualclub.com/motomanuals/index.php?cid=12
Feb 12, 2011 | 2008 Yamaha Royal Star Venture
I have a bushnell Northstar telescope #788831am. Is there a place i can update the are i am looking from. It knows las vegas nv and does not pull up reno nv. I need help.
I don't believe they have an "update" web site. However they do have a customer service web site here:
http://www.opticsplanet.net/bushnell-warranty.html
According to the manual PAGE 14 choose the closest city.
See this: http://www.bushnell.com/manuals/telescopes/78-8831_Northstar_GOTORV_4L.pdf
Apparently once you center the two alignment stars it does not matter. The closest city gets you near the alignment stars if Time, Date, etc etc are set properly.
There does appear to be a latitude longitude selection in the menu-- see the manual above. See if you can also set the exact Lat-Long in the hand controller.
Jun 02, 2010 | Celestron NexStar 8i (600 x 203mm)...
Instructions
I"ve been an amateur astronomer for "over" forty years, started when i was eight. Stars aren't that impressive, most look the same....i spend my telescope time with a cheap $200 21/2 inch "Refractor" and have seen all planets except pluto, i had to use a 41/2 inch refractor just to be able to view Neptune and just barely saw it and yes it was Blue!! Refractors are best for planet viewing. Dont waste your time with viewing Mercury or Venus...not impresive! The best looking (but not in the next few years because of ring alignment) is Saturn...hurry up and you might still get a chance to see the rings a little before they go into what i call hibernation mode, they'll make a straight inclination though the planet which makes for not so impressive views...next most impressive and one i view the most is Jupiter and its for moons Calisto, Ganymede Io, and Europa...you will always see these in different orbits. But i just use a pair or Celestron Binoculars 15 x 70s..i use them to look at the Moon, Mars, Jupiter, Saturn, Comets, overhead comunication Satilites passing bye..and the most awsome of them all the "Orion nebula" colors are outstanding, and if your real good at knowing your constellations you can locate the Andromeda Galaxy. It'll look like a buffy cotton ball with binoculars..dont view the sky ever with a full moon.it makes for poor viewing,but this is where the Reflectors like a 4"Newtonion or lot bigger like at least an eight inch Cassigrain..these telescope are made to view whats called "faint fuzzies", Nebulas, Galaxies, star clusters etc. 40 years ago i cold look up in my local skys and not have to worry about light polution..so i go out to the deserts with just my binoculars...they are so convienient. Start to learn the sky with binoculars...it"ll be well worth it! The one Great thing about binocs is that everything you view is right side up as opposed to telecopes upsidedown. To locate planets they will track within 10 degrees in the path that the sun takes. If you look and see some really bright stars that dont twinkle, chances are that it will be Jupiter, Saturn or Venus..but you will only see Venus in the early mornings or late evenings..Mars is a little trickier, sometimes its small and red and every few years it can be as bright as Jupiter when its at it closest to the earth!
http://www.paulni.co.uk/images/EarthinPerspective.pdf
type in this link i think above i think you enjoy! later.
Apr 02, 2010 | Galileo (G118DX) Telescope
How does a telescope used, and can we see a star through it even if the star is really really far?
Put the eyepiece with the largest number written on it into the telescope. Go outside during the day and practice focusing on a distant object.
Stars ALWAYS look like -------------- stars no matter what telescope you use. They are all too far away to see as a "disk" , always just points of light.
The closest star is Proxima Centauri at 4.2 light years away.
That is about 25 TRILLION miles!
Oct 30, 2009 | Tasco Astronomical 302675 Telescope
What is the spark plug sequence on a 1997 Toyota Corolla, 1.8 liter?
Facing the vehicle from the front, it starts at the far left and goes in order - 1 2 3 4. On the distributor cap from the same perspective, top closest to the front is 1, bottom closest to the front is 2, bottom closest the firewall is 3 and top closest to the firewall is 4. This is for a 3sfe engine.
Jul 07, 2009 | Toyota Corolla Cars & Trucks
Aligning NorthStar For The First Time
don't know which northstar ( I presume that's the software) your using but you may find help here http://www.bushnell.com/products/other-products/telescopes/instruction-manuals/
Nov 12, 2007 | Bushnell 78-9669 Telescope
Bushnell NorthStar 78-8890 (300 x 90mm) Telescope Logo
71 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
