Question about Whirlpool Washing Machines
The cold water will not work. All hoses are hooked up correctly, and the cold water is turned on.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
2 screws on timer console . may be on back side. flip console back and remove two clips. body will set off. on your valve to check try( for test purpose only)switching hoses and wires on solenoid ( if cold comes in now, you know you have a bad solenoid)or check solenoid with an ohm meter.
Posted on Jan 31, 2010
The cold water does not flow correctly, there are no kinks or blockages in the hose. I believe it is the cold water solenoid as the hot water works fine.
If you have any cold water at all the filter screen in the water valve is dirty.
Turn off the cold water.
Remove the hose from the cold water valve connection on the washer.
Use a bent paper clip to remove the filter screen from the valve.
Clean the screen and replace it in the valve.
Re-connect the water hose and turn the cold water supply on.
If the screen is already clean,replace the water valve on the washer.
Jul 17, 2011 | Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Aug 10, 2009 | Maytag Performa PAV2200
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Hooking up the cold and hot water in back of the washing machine
In a word Yes!!
The machine will fill with Hot water to rinse and if that water is as hot as the normal supply your clothes will shrink and the colours will run.
You need the hoses and the supply to the hoses to be correct so that when you put it on a cool wash it fills with cold water and brings the temperature up to the right level.
Bringing in hot water will kill the soap powders action.
Also the machine adds hot and cold water to make sure that it gets a correct balance for other programs
If you are not sure how they are connected then look at the back of the machine, there should be either a H and C stamped into the backplate or the inlets are Red and (White or Blue).
If the hoses coming from the fawcets are the same colour then take one off the machine place the end in a bucket and turn the fawcet on , if it does not get hot then its the cold one so then make sure it goes back onto the C or the White connector
Jun 22, 2009 | Hotpoint Washing Machines
Water Temperature is hot on all rinse cycles Water temperature on rinse on all modes is HOT.  Water is hooked up correctly (the delivery folks hooked it up when installing).  Steaming hot - too hot to...
if your gettig hot water on rinse.your fill hoses are not correct.rinse is only cold.switch the hoses.if that dosent solve the problem call for warrenty
Jan 03, 2009 | EuroTech EWF150 Front Load Washer
Water fills to wash, but trickles when rinses
you can try cleaning the filter at hose end, where it hooks into the unit.make sure your cold awater supply is good.
Apr 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire affinity front loader washer
The E-70 code means your hot and cold water hoses are hooked up backwards. Double check that your hoses are hooked up correctly.
Aug 31, 2007 | Frigidaire ATF6000ES Front Load Washer
Hook up
this one is simple. first connect the hot water hose to either inlet. now turn on washer for cold water only. if no water enters machine, you have it correct. now connect cold water to other one. now repeat cold water wash...does water come in?
Aug 17, 2007 | GE WSM2780W Stacked Washer / Dryer
GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Mar 01, 2007 | GE WHRE5260E Top Load Washer
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
