Question about Seiko Mantel Clock
The speaker is chiming funny. Can we get a part to fix it?
  • 3,741 Answers
Check out the internal connections of the speaker.any of the wire is got cut in between and is touching any of the metal part in the unit. either the speaker internal capacitors are getting short .it has to be checked and replaced. keep updated.thanks.
Posted on Jan 31, 2010
2009 silverado 2500hd wt Diesel chime in ceiling does not work for any notifications, seat belt, low fuel, turn signal on, door any clue where to start looking.
The chime system is a class 2 databus. The chime is actually created by the factory radio and plays thru the left front speaker. If the radio is non factory and the appropriate kit was not used ( which has a speaker for the chine) or the front left speaker is blown then you won't have a chime. If you do have a factory radio and the speaker plays the music fine then the problem lies in either the data circuit or the radio. If you have an aftermarket radio and the correct wiring kit was used then either there is a bad connection, blown chime speaker or defective kit.
Aug 09, 2016 | Chevrolet Silverado 2500HD Cars & Trucks
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
May 13, 2016 | 2009 Chevrolet Cobalt
How do I disconnect the chime from automatic door .Had to cut cable as it jammed . Took out fuse but radio and clock now do not work .Can I disconnect wire from chimes .I knoe it comes from speakers .
try this
disconnect battery
undo the fuse box and look at the wires behind that fuse you pulled
check that only radio and clock wiring are fitted there
the chime may its own power source
i could be wrong
i thought chime was separate to sound system speakers
and comes from a small but loud sound device on the instrument panel circuit board ..much like a computer
May 28, 2014 | 2005 Buick Terraza
No chimes just static
chime is run through radio and sounds through driver side speaker. If chime is sounding, then speaker most likely problem..
Oct 23, 2013 | 2004 Chevrolet Tahoe
TRYING TO FIX A DOOR CHIME ON A 2002 PONTIAC SUNFIRE. NEED TO LOCATE WHERE DOOR CHIME IS LOCATED ON THIS VEHICLE
In most vehicles the "chime" is located in the dash around where your 4 way flaser is. It could simply be the door switch also which is a little button that depresses when you close the door to open the circuit shutting the dome light and chime off. They are easy to change and inexpensive. Hope that helps.
Aug 05, 2011 | 2002 Pontiac Sunfire
My Chevy Venture 2003 door chime on drivers side chimes without key in ignition with door open. Before this happened my dash lights acted funny and then went out. When I shut off the van and opened the...
Sometimes the ignition key does not "deactivate" when removing the key...try wiggling the washer behind where the key goes...sometimes this sticks...:)
Dec 08, 2010 | Chevrolet Venture Cars & Trucks
2008 Cobalt - Front speakers not working and no audible turn signal. Both stopped working at the same time.
In my 2008 Cobalt, the front speaker in the driver door went inoperative - no turn signal noise, no warning chimes for door open with key in, seatbelt chime, low fuel chime, and of course, no music. All of those sounds come through the speaker. I switched the driver door speaker and the passenger door speaker, and now I have all of those noises back.
If you have manual roll down windows, you'll have to buy a special tool to remove a little clip that's behind the roller handle. This tool was included in a kit for about $7 that I bought at Harbor Frieght, but you might be able to find the kit at other auto parts stores. Google "removing window crank" and you should be able to locate a video that shows how to get it off.
Anyway, I switched the speakers and now we just don't have music coming out of the passenger door speaker, but at least we have all of the warning chimes and turn signal clicking noise again.
The dealer wanted almost $200 for a new speaker and to replace it (labor). Rediculous.
Jul 20, 2010 | 2008 Chevrolet Cobalt
No warning chime for 2006 Ascender
I don't think it is a fuse.
The warning chimes for this vehicle come through the radio and are play to the speakers and if I remember correctly the chimes play to the left front speaker.
I would check for a faulty speaker or wiring to the speaker.
Sep 09, 2009 | 2006 Isuzu Ascender
2001 Oldsmobile Alero Speakers/Chimes
Hi!
Please check the link for the wiring info--
Alero 2001 wiring diagram
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Feb 24, 2009 | 2001 Oldsmobile Alero
Home Logo
47 people viewed this question
Top Seiko Home Experts
k24674
Jimmy Accardi
Are you a Seiko Home Expert? Answer questions, earn points and help others
