Question about Ecoquest Fresh Air Air Purifier
There is a black mark on one side of the purifier plate. does it matter if that is on the top or bottom?
    President:
  • 670 Answers
It does not matter whether the mark is on the top or bottom, it will work fine ether way.
Posted on Feb 10, 2010
Where is the ionizer wire?
On the opposite half as the plates. Look for but don't touch the big insulator at the top. The wire run from it to the bottom of the machine. Older ones have a cleaning bead and you must turn the entire machine upside then right side up several times to clean it. Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
Jun 23, 2014 | Ionic Pro TURBO Air Purifier
Ok replaced lamp and starter and now it wont come on ?
Something is not reassembled correctly.
Check all connections, insertions, turnings, etc.
The lamp/starter need to be inserted so they "click" or "seat" firmly.
The plate needs to be inserted into the little "tracks" at the top and bottom of the plate. The contact fingers must press firmly on both sides of the plate. Bend them so they do.
The back screen needs to be inserted so the little pull-tab sticks out at the top and so the safety switch (if there is one) is depressed.
The back needs to be screwed back on firmly.
The plug needs to be inserted firmly, FIRMLY, FIRMLY into the back of the machine.
The little safety switch near the plug with the 0/- markings needs to be set to allow power to the machine (try it with power plugged in).
If all else fails, check the fuse (near the plug.)
If nothing works, call customer service (Vollara is the new name for EcoQuest) at 1-800-989-2299. They can walk you through these steps if you ask them to, then give you other options. Use #16618 as your dealer referral number if you are not in touch with a registered dealer.
Jan 25, 2011 | Ecoquest Fresh Air Air Purifier
How to clean ozone plates
Unplug the machine.
1) Remove the back screen, then pull out the plates.
2)Soak them in a 1 to 1 solution of PLAIN ammonia and warm water for about 5 minutes.
3)Scrub with a toothbrush or soft veggie brush.
4)Rinse well.
5)Blow dry. Do NOT use any cloth or paper of any kind. Avoid touching the screen with fingers.
6)You can also clean the contact points with a cotton-tipped swab and alcohol.
6)Reinsert plates, making sure that they enter in the "groove" or track, both top and bottom. Make sure the contact fingers press firmly on both sides in the screen area.
Jan 19, 2011 | Alpine Air XL-15 Air Purifier
I cleaned my io breeze quadra plates with rubbing alcohol reinserted and turned it on, it made some crackling noises and started emmiting a burning smell like a hot transformer pulled insert plates found...
You will need to take unit apart to check both the and bottom. Start either at top or bottom go over the circuit path of hi voltage grid wire check for more burn marks. Insure hi voltage insulated wire coming from transformer is not broken. This will be located at bottom of unit you will have to take top pc board off and control transformer to get to hi voltage transformer, then when that is removed you will see the hi voltage connector I was talking about. That wire is soldered on and is a very delicate connection. Make sure wiring soldered. Hi voltage transformer should be ok if you did not leave unit on for a long time while you had your loose connection in the grid wire.
Dec 14, 2010 | Sharper Image Professional Plus Ionic...
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
I purchased my purifier about 3 years ago but it has only been in use for maybe the last 2 years and it just stopped working. When I plug it in and turn it on nothing happens? I dont think for such a...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse for the ozone part it is marked F21 on the same board
Aug 22, 2010 | Ecoquest Flair Air Purifier
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
Our ionic breeze doesn't want to light up down in side the machine what could be wrong?
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Mar 08, 2010 | Sharper Image Ionic Breeze GP SI720 Air...
Have a silent air purifier quadra model # s1637
If, when you push the on button it sizzles for a sec and then shuts off (clean light goes on), I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
Feb 12, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Kenmore ac2044-1 shuts off
Take Cell out and examine closely with flashlight for debris and bent aluminum cell plates or ionizing wires.
Make sure all plates are more or less clear of one an other with fairly even spacing between them and no kinks on their edges.
If any are to close together it will cause a cell overload that will cause the Clean Cell to display and or completely turn unit off all together.
Mar 28, 2008 | Kenmore AC2044-1 Air Purifier
Ecoquest Fresh Air Air Purifier Logo
63 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
