Question about Magic Chef CGR3725 Gas Kitchen Range
My Magic Chef gas oven thermostat is not working properly. At 400 degrees it only heats to 200 degrees and at 500 degrees it only heats to 300 degrees. Do I need to replace it or can I calibrate it?
  • mcturnbloom Jan 31, 2010
    Thanks for the assistance, but I actually just figured it out on my own...I just needed to calibrate the thermostat.
  • Chuck Smith May 11, 2010
    an accurate and complete model # would help bunches. thanks
  • 111 Answers
Ther is a temp sensor that goes from the control valve to the oven,this may be the problem, make sure sensor probe is tight where it screws into the gas valve and other end is not just hanging in the oven, it attaches to the top of oven,if it's where it's supose to be, I'd change that first
Posted on Jan 31, 2010
    Novelist:
  • 127 Answers
Well after checking the model # u listed cgr3725 there are 4 sub models from that.. all appear to have the same components for oven controls.
you will not be able to "calibrate" 200 degrees out of the control, either the temperature probe has been damaged, the control is bad, or your ignitor is just plain getting weak and not pulling the required 3.3-3.5 amps thru it to allow for full flame height and normal temps and heating times.. you would need to test the current(amperage) flow thru that ignitor to confirm its failure.
good luck, and have fun..
ttfn
I set my magic chef oven at 400 degrees,and it shuts off before it reaches the temp.
Have you checked the internal temp with an oven thermometer?
The thermostat might need calibrating or replacing, or, (if electric) the oven might be seeing an "overload" condition and shutting off.
Dec 12, 2016 | Magic Chef Kitchen Ranges
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
My Majic Chef Oven model CGR3760 is taking a long time to heat up. It took 1 hour to reach 450 degrees! Not sure if this might be a thermostat issue or burner. Penny
Turns out it was the ignitor going bad but not totally gone. We are waiting on a part to come it to replace it. Thanks. By the way, this is a neat service, keep up the good work!
Jan 31, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Nov 10, 2009 | Magic Chef Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
Oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
Sep 09, 2008 | Magic Chef CER3740 Electric Kitchen Range
Pilot light out/will not go above 350
Sounds like the thermostat controlling the gas valve in the oven is not working, I’m trying to find if the oven igniter is electric, but believe the igniter is electric. If it does light then not regulate the temp above 350 degrees, I am convinced the thermostat control is bad.
Oct 23, 2007 | Magic Chef CGR3725 Gas Kitchen Range
Magic Chef CGR3725 Gas Kitchen Range Logo
662 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
