Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Rotary brush is not spinning - Bissell 6594 PowerForce Bagless Upright Vacuum
  • 701 Answers
That means that you need to replace the belt. Here is the belt you need and the manual:
Bissell PowerForce Belt and Manual
Posted on Jan 31, 2010
    Problem Solver:
  • 16 Answers
Replace the belt
Posted on Feb 02, 2010
On my dyson DC22 canister the rotary brushes stop working, the suction is good. I checked the hose nothing. but a red light comes on on the start button. what to do?
Dyson don't give much help here. The wire to the head must be hidden in the hose? Can you get to where it enters the head and the body of the suction unit?
https://www.dysoncanada.ca/en-ca/support/dc22/dc22-motorhead
There are some helpful videos here though.
dyson DC22 head not spinning Google Search
Nov 21, 2016 | Dyson Vacuums
Dyson dc59 troubleshooting
Have you checked the rotary brush at the front. Although IO dont have the same model of dyson I need to clean out the dog hairs that get wrapped around the main rotary brush which is easily got to by turning the catches with a coin under the cleaning head. They should have a little arrow or padlock symbol showing which way to turn them
Aug 17, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
When I push my vacuum with the rotary brush on carpet the rotary brush head shakes. It's fine when I pull it back. I just can't push it.
it may be time to replace the belt on the unit. sometimes when the belt slips (not broken yet) it will give you the same effect. It will also sound a little sluggish too. replace the belt and you should be ok for 1 year. if your using the unit more than one time a week you may have to replace the belt 2 or more times a year.
good luck.
Nov 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to change the belt on an upright silencio
remove the 2 screws from the bottom...remove bottom cover.....pull the rotary brush straight down and out....put new belt in the groove on the brush then reinstall brush and put the belt around the metal rod thats inline with the groove on the rotary brush...put cover back on and put the 2 screews back in...thanks and have a great night
Jan 03, 2010 | Vacuums
The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Jan 03, 2010 | Hoover V2 U8140-900 WindTunnel Upright...
The Rotary Brushes do not spin.
that model has a direct drive brushroll motor and transmission. the brushroll motor is most likely bad test it with a continuity tester if it tests open or high resistance than its bad
Jan 03, 2010 | Hoover U8147-900 WindTunnel V2 Bagless...
The rotary brush stopped spinning. I believe its
I have seen belts wear faster than that, believe it or not. Here is a link to the belt you need and a link to the manual:
Bissell Health Home Replacement Belt
Bissell Healthy User Guide (PDF)
Nov 17, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Proheat Plus turbo brush does not work.
No water or soap is coming through, what do I do?
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
226 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
