Question about KitchenAid Superba® Architect® KSRP22FS Side by Side Refrigerator
There is an accumulation of ice on the bottom of the freezer...model #KSRD22F..any suggestions?
  • KitchenAid Master
  • 2,696 Answers
You have a blocked drain, shut off the control to the fridge so the fan doesn't blow,take out the racks and remove the inside back wall of freezer,melt out the ice with a hair dryer,now you have to unblock the drain,i use a steamer to do this,you can get one for around 50 bucks,they have alot of other uses,good tool to have,stick the nozzle in the drain hole and blast it,the steam will sanitize the line and clean out whatever is in the drain,when you think it's clear pour hot water down drain to make sure it's clear.a piece of food or other stuff could have fallen into the drain or slime builds up in the line over the years
Posted on Jan 31, 2010
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
I have a Kenmore bottom freezer model 596.75934401. The refrigerator top has stopped cooling while the bottom freezer is working but showing some accumulation of icing. I have unplugged the regrigerator,...
There are a couple possibilities. You need to make sure the evaporator fan in the freezer is working, it circulates the cool air to the top. More likely your coil in the freezer is iced up due to defrost part failure, either the timer or the heater assembly. The back panel is going to have to come off. If you defrost the coil completely, the unit will work again until it ices up again. You have to have the defrost system diagnosed and the defective part replaced
Jun 25, 2011 | Kenmore Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Water is accumulating inside the bottom of the freezer.
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 13, 2009 | Frigidaire FRS26R4A Side by Side...
Ice accumulating in the bottom of the freezer
blower may not be working as efficiently as it should cause bad circulation of the chilled air.
Jun 27, 2009 | Maytag MFD2562KE Bottom Freezer French...
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Ice accumulating inside freezer
the defrost element under that shelf has burnt out or has a loose connector.
May 01, 2009 | Refrigerators
KitchenAid Superba® Architect® KSRP22FS Side by Side Refrigerator Logo
127 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
