HP# J4580 All-in-one copier: paper jam signal flashing, there is no paper in it.
  • Annie Anderson Feb 02, 2010
    will have to try first.
  • 3,741 Answers
1) turn the printer ON. 2) remove the cartridges out. 3) then without installing the cartridge, just directly remove the power cord wire from the printer.the printer will turn OFF. 4) then with your hand tap the sides of the printer for couple of minutes. 5) then reconnect the power wire to the back of the printer. 6) turn the printer ON. 7) insert the cartridges again in the printer. 8) then check out.does the paper jam error light comes on. 9) if still the same problem then its the problem of paper sensor. 10) there is a paper sensor in the printer which detects the paper in the printer. if that sensor is moved from its position then it will detect the paper in the printer jammed.so sensor needs to be checked.its located on the upper sire of the paper tray.from where you insert the paper.in the inner side where the end of the paper reaches.there is a sensor.its a thin delicate part which moves up and down by the passing of the paper. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 31, 2010
Hp officejet j4580/ repairs
do u have checked carriage sensor strip may be strip is broken that s not senses carriage unit and moving UN control and hit at the left right end
Jul 15, 2014 | HP OfficeJet J4580 All-In-One InkJet...
Clearing a Paper Jam On Top - HP Officejet J4580
Lift up the top and look for the torn piece of paper. try moving the roller with you fingers it will not print untill you get all the paper out.
Jan 14, 2011 | HP OfficeJet J4580 All-In-One Laser...
Hp officejet j4580 paper jam message but no paper is jammed
you can disconnect the printer fron the power outlet and wait 5 min and reconnect.. if don`t resolve the problem you need to open the printer and find a smmal piece of paper jammed in the rolling. pls click if my solution was helpful and good luck
Dec 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
I have an hp j4580 all in one, and it keeps telling me that there is a "carriage jam"...I can't figure out how to fix it
Open the top and look to the right hand side. There is most likley a piece of paper jammed and keeping the carrier from moving the home position. You may have to pop off the small door on top.
Oct 14, 2009 | HP OfficeJet J4580 All-In-One Laser...
How can I fix a paper jam on HP OfficeJet 4580
hi,
Paper jam messages can be true or false. The product might report a paper jam when there is not any paper jam. The following steps resolve both true and false paper jam messages.
this link will help you out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368841&cc=us&lc=en&dlc=en&product=3645100
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error message: paper jam, there is no paper jam.
The sensor that would detect the paper jam is tripped.
Fiddle with the sensor to release.
Aug 07, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hi, my HP 4580 says there is a paper jam, but there doesn't seem to be one! Help???!!!
Sometimes the paper jam is caused by a tiny piece of paper. It can be smaller than a postage stamp, covering the paper sensor. Or it could just need cleaning. Look for very small piece of paper or look on edge of paper guide for small lamp sensor
Jun 12, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet J4580 paper jam
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Feb 24, 2009 | HP OfficeJet J4580 All-In-One Laser...
18 people viewed this question
jasbo
jasbo
