Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
55 rancher Husqvarna got very hot due to no oil in gas, and will not start again.
  • 431 Answers
The piston rings rely on the oil in the gas to lubricate the cylinder wall. More than likely, the rings are now too small to provide the proper seal for enough compression. It could also have worn the cylinder wall more than the rings, the end result is the same.
You can try to remove the plug, put in about a 1/2 teaspoon of oil into the plug opening, slowly pulll the rope 1 time to let the oil coat the ring & wall & then put the plug back in & try to start it. Use a little extra oil in your gas to provide thicker lubrication. good luck
Posted on Jan 31, 2010
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
55 rancher fuel line
I put a stiff wire inside my gas line and put a little oil on teh grommet,
Feb 01, 2012 | Husqvarna Garden
Husqvarna 460 rancher: oil pump not working. Clutch ran hot a few times. When the bar and chain are removed no oil appears from the supply port
The oil pump is adjustable ( 3 positions ) the adjuster screw is located under the crankcase below the sprocket, there is also a filter in the oil tank, you will need to gently lever out the oil pick up pipe from the oiltank, it has a grommet in the centre to keep it tight in the tank, failing that there is a nylon gear driven via the drive sprocket, this may have become damaged.
Oct 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna rancher 55 chainsaw having problem starting have spark new spark plug, plug is wet after trying to start it
You need to check that this machine is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing ( seizure ), and the cylinder will need to be removed to assess the damage
Aug 27, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Husqvarna 55 rancher-just put new piston ring and cylinder.saw start right up and idles.when i try to acellerate it bogs and try to stall.when I let off gas it idles fine again.I tried turning mixture...
The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
Mar 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My husqvarna rancher 455 is brand new and does not start any more after a first use which was OK what should I do now ? Thnaks
Bring it back to your dealer.Did you mix the gas and oil correctly? Did you leave gas in it for more then a month? Have clean fresh gas? Flood it?
Dec 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
327 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
