Question about DCS Ovens
I have a DCS oven that is approx 20 years old that is in need of a thermostat. The technician said that they are no longer available. Can you help me find this part and recommend someone to install it? Thank you. Lou Giannotti Newtown, Pa 18940 215-595-7841 ljgiannotti@aol.com
TaPuna
  • 70 Answers
SOURCE: How to install built in oven
you need to make a hole in your joinery the size of the oven put it in and you will need 4 screws to put in to hold it to joinery you will also need a 4mm twin and earth TPS cable going straight to the switch board on it's own breaker. hope this helps
Posted on Sep 09, 2008
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
aborcass
  • 2651 Answers
SOURCE: need deminsions to purchase new oven
every oven has different dimensions, the easiest and best thing to do, is to slightly pull unit from the cabinet its installed in and measure the max. opening both height and width.--- if its a freestanding range that you are talkin about the dimensions are standard inches,, 20-24-30-36.
Posted on Dec 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: I need the bottom bake element for my kenmore
Take the element to any appliance parts store. They can match it to a usable element.
Posted on Nov 19, 2009
heatman101
  • 43501 Answers
SOURCE: hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 | DCS Ovens
Replacement thermostat for old GE oven
they say you can use a G.E. part# WB21X5320 in place of the WQB24X176 and supposedly it is available from Appliance Parts Warehouse Online
Oct 01, 2012 | Ovens
The bulb in the main oven no longer works. The problem is that we cannot unscrew the lamp cover, in spite of following instructions in the manual. How can we do this? It is a U1421 oven, approx 10 years...
Hello, I find that spraying pam cooking spray around the lamp cover and letting it sit for a while will help on removing that cover. Rember to clean the excess spray before using the oven...Hope this helps.
Jun 06, 2011 | Neff U1421 Double circotherm Electric Oven
My DCS double ovens do not have any display left ( all th egreen display has faded in past three weeks) on the display panel. can you give me an idea of what i should do next Thanks Jim
The replacement part is (or was) Fisher & Paykel #16252 Electronic Oven Control (app. $240 in '06 when I replaced the last one). For what it's worth, I have had two boards fail in the past 10 years. On both of my boards, capacitor C3 (68 uf, 35v) is the part that failed. I replaced the bad cap on both boards (cost $0.16) and the displays were back to normal. Obviously, the failed caps were the manifestation, not the cause of the problem with my boards.
Dec 12, 2010 | DCS (WOTD-227) Double Oven
Dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Jul 19, 2009 | DCS (WOTD-227) Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS Single Wall Oven Model WO-130-SS
Order part #211708 from 1-888-281-5698 DCS Fisher@Paykel new Zealand. Only need philips head screw driver and twenty minutes. This part is a upgrade for lcd only. old part was a three part system, but no need for three parts only lcd screen.
Jul 07, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Problem with dcs oven
Did you get fix for this? I had the exact same problem-thank you!
Apr 10, 2008 | Ovens
Ovens Logo
55 people viewed this question
Top DCS Ovens Experts
ashburton
Joyce Nokleby
ray gallant
Are you a DCS Oven Expert? Answer questions, earn points and help others
