Question about Frigidaire GLTR1670A Front Load Washer
Motor wont run
I replaced the shocks and upper spring that was broken. Now the machine will fill and drain but not spin. This is a front load frigidaire washer. I dont know if it could be a wire or the motor or how to tell.
  • 619 Answers
Your door lock is bad. Don't trust the door lock light because this will fool you. Even tho door locks 1 of the circuits is not continuing. Replace the door lock. Very easy to do. Do this by peeling back the door boot at the lock side. Reach hands inside for access to wiring and remove door lock switch.
Posted on Jan 31, 2010
I have a Frigidaire front load washer that is suddenly making loud banging noise during spin cycle, could it be a belt?
Check for broken/disconnected springs, disconnected/faulty shock absorbers (dampers). For this you have to disconnect the mains power and open up the machine. Spares can be obtained from this very site - Fixya.
Mar 28, 2013 | Frigidaire Washing Machines
Frigidaire gltf1670as0 front load washer not agitating or spinning. fills drains and progresses through the cycle otherwise fine.
Hello paigeterrajr - Well, if there isn't any motor movement, it could be the door switch, the motor, or the main control board. Since the shock absorber could possibly be broken as well, it is possible that the unit thinks that it is not balance properly which will prevent it from going into a high speed spin/agitate. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
Frigidaire gltf1670a front load washer not agitating or spinning. Can my broken shocks have anything to do with that?
Your broken shocks could have disconnected some wires due to the vibration. Plug off the wall, open up the machine to examine. In the process you have to change the shocks. Disconnect and refit each terminal, especially the connector to the motor.
Click if helped.
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer, water enters but the drum will not rotate or turn. when the control is advanced to spin wahser will drain but no spin action.
After removing the back from the washer I discovered that the shock on the left (looking in from the back) is broken. Also looking at the control board there is power on both sides of the fuse and after removing the belt the motor will not turn when control is placed in the wash or spin position.
My issue now is removing and replacing the shock and determining if the motor or the control board is the problem.
I will send an additional message on the solution that I came up with.
Apr 18, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigadaire front load washer, drum is very low in
Is the drum bouncing around?
Remove the front lower panel and the top from the cabinet. Replace the shocks and/or tub support springs if they are broken.
If the spin is noisy, there might be a problem with the inner basket or the tub bearing.
Mar 05, 2009 | Frigidaire Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer fills, drains, but doesn't spin
Is the drive belt broken, assuming the motor runs. Or has a pulley come loose?
Jan 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery Heavy Duty Front Loading Washer, FWT445GESI
If you access the bottom panel you can see the shocks mounted from the base of the machine to the tub. you will need to take the top panel off and you can see the springs the are mounted about 1/2 way in at the top and connect to the to off the tub
Nov 02, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Shocks broke, now drums spins freely
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Oct 16, 2007 | Frigidaire GLTF530DS Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
200 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
