Question about Kenmore 24032\24036 Top Load Washer
Seems like all the water is not geting pump out on the spin dry does that mean belt needs adj.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
This washer does not have a belt. most likely clutch needs replacing. part # 285785. 3 bolts holds tranmission. clutch on top of transm.
Posted on Jan 31, 2010
LG WM2101H won't dry until many cycles
Won't dry? I guess you mean spin enough water out? Depending on age, warranty, It sounds like a worn or bad drive belt or possibly a problem with the discharge pump not working properly.
May 04, 2015 | LG Washing Machines
Makes grinding sound when agitating & when spins clothes must be wrung to get more water out
Your pump is going out. I have seen em lock slap up in one direction only and not leak but the bearing be gone. Easy fix. 3 s/8th inch screws hold the pump to the base. a couple screws hold the service panel on and you need pliers to get the hose clamps loose. The belt comes off easy by hand no tools need. The belt also might need to be changed which is simple. Let me see if i can find a video.
Nov 15, 2013 | Maytag HAV2360A Top Load Washer
The water won't come out. The carpet is still dry after repeatedly pushing trigger to dispurse water on carpet.
If it will not disperse water then that means that the pump belt needs to be replaced. Here is the belt you need:
Proheat pump belt
May 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Hi, I have a Maytag Washing Machine. Model Number: LAT7793ABV It seems to wash fine, but when it gets to the "Spin" part of the wash, sometimes it doesn't spin, and if it does spin, the clothes...
Several items can cause no spin or slow spin. I'm assuming the motor runs during spin and the water all drains out. A worn or damaged belt can cause your problem. Always replace the drive belt and pump belt at the same time.
Check for smooth and non binding motion of the motor in it's carriage.
A failing bearing (either tub bearing or spin bearing) will restrict tub motion in spin.
A garment in between the inner and outer tub will also restrict tub spin performance.
Apr 28, 2009 | Washing Machines
Water not draining
check if anything is blocking the way of the drain pump ...else the drain impellor would have broken...
thankyou
Dec 05, 2008 | Washing Machines
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Water not draining
The belt may have failed due to the pump seizing up.
Remove the belt and turn the pump with your hand. If the pump seems hard to turn (should turn freely) replace the pump.
Jun 25, 2008 | Maytag SAV4655A Top Load Washer
Tricity Bendix BIW 105W Washing Machine
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Feb 12, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
