I have two Sub-Zero units that have been continually problematic since original purchase. I'm afraid I would recommend them.
Currently the Refrigerator section is 55 degrees and the freezer is as cold as usual.
700TCI 700BF
thanks
Comments:
Feb 18, 2008
- Any chance someone has a sub-zero repair manual?
please let me know.
Feb 22, 2008
- Instantly you can rule out the evaporator as I stated the freezer was "frozen" as cold as usual. The clue is that the refrigerator section was warm. This narrows the problem down to the switches that activate the fan i.e. the two drawer switches and ice maker switch. If all of those test correctly for continuity then the fan that moves the really cold air to the refrigerator section should be checked. When checking the fan remember it does not operate if the system is running thru a defrost cycle. Most of the time a visual check will work -
My Sub-Zero is making this humming noise, but not all the time. It seems to happen randomly, and...
(More)
My Sub-Zero is making this humming noise, but not all the time. It seems to happen randomly, and wont do it again for weeks. It sounds like it's coming from the top, and I'm thinking about trying to clean out all the dust and build up that's probably collected up there to see if that helps. Also, the area between the frdge and freezer feels hot to the touch. Not inside, but the face where the doors close. I had never noticed, but my soon to be mother-in-law was over and I guess she touched it and asked me if that was normal. I'm hoping this isn't the begining of the end for my fridge, and I would love to know what to do in order to solve my issues and keep this fridge running for a long time. I really can't afford to replace it, thanks for any advice!
freezer fan on westinghouse side-by-side always running. Cools freezer and fridge just fine, but...
(More)
freezer fan on westinghouse side-by-side always running. Cools freezer and fridge just fine, but hardly every shuts off. Where are the coils underneath? I see lint under there, but dont know where the coils are to clean then. Are they in the back?
This is a Subzero refrigerator from the late l980s that was refurbished in 2006. The noise is...
(More)
This is a Subzero refrigerator from the late l980s that was refurbished in 2006. The noise is perhaps from a compressor or motor located on top of the refrigerator
The Alarm on the refrigerator goes off after the door is open for 3 or 4 seconds. Is there a way to...
(More)
The Alarm on the refrigerator goes off after the door is open for 3 or 4 seconds. Is there a way to disable the alarm feature? When I push the alarm button it disables the alarm for the moment but the next time I open the door the alarm sounds again. Would love to eliminate this alarm as it is very annoying! Thanks for your help!
I am looking for an afordable solution for the three stainless panel I need for my fridge two...
(More)
I am looking for an afordable solution for the three stainless panel I need for my fridge two drawers and the main door I am also looking for the ice bubet as well as a door shelf
