Question about Acer Computers & Internet
Hi i have an elonex exentia, i had a problem with it, it was full of trojons. i had to reload windows the monitor is now flashing.i say flashing but i mean it goes black, you can hear that the machine is still connected and the program or programs are still running, when it flashes back you can carry on where you left off until it flashes again (because you cant see what your doing).i think i may have the wrong driver some here or the graphics card is going im not sure i wonder if anyone else has had this probelm and how to fix it.someone said it was the Ram but ive replaced the Ram and upgraded it but no luck
SOURCE: Dell LCD monitor flashes white every second, and then goes black
Take a very good look at the power supply capacitors. Are any of the tops of the electrolytic capacitors domed? If you replace them, use a high frequency high temprature replacement to prevent a repeat failure. Don't use a standard 85 degree cap. It won't last.
Posted on Jul 24, 2007
  • 6966 Answers
SOURCE: HP Monitor blanking out on full screen mode
Hi, I read this somewhere (can't recall the site). Go to your desktop properties (right click on any clear area of your desktop); Settings tab; Advanced button; Troubleshoot Tab; Uncheck Enable Write combining; Reboot your PC. If this does not fix the problem, you can always revert back. Hope this be of some help. Good luck and kind regards.
Posted on Jul 30, 2007
  • 63 Answers
SOURCE: flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor
Posted on Aug 27, 2007
SOURCE: Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Posted on Mar 10, 2008
  • 1498 Answers
SOURCE: Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Posted on Oct 30, 2008
Elonex web book dead?
There is no information on that. The site is down. Can you post the exact model number?
Jan 15, 2013 | Computers & Internet
Flash player won't install on. My elenox. Tablet. What can. I do
From Elonex:
"FYI - Android 2.2 unfortunately will not support flash, we are currently in communication with Google reference to this in order to try and make the unit flash compatible.
Elonex Support"
I wouldn't expect to see Flash until a system upgrade is available for your tablet. Sorry.
Mar 26, 2011 | Computers & Internet
Hi looking for xp drivers for my elonex prosentia 2000 computer, just reformatted after virus, need lan vga and audio. thanks
I don't see "prosentia" there but there IS a couple of 22XX series eXentia pro's which is close. Also look around on the computer there might be another model number that matches something on the webpage shown at the above link. I assume no recovery CD is available - how about a recovery partition - you could try calling Elonex there is a "contact" link in the top right corner of the above webpage that yeilds a phone number to call that might be useful. Try that & post back with your results.
Mar 03, 2010 | Computers & Internet
Gateway 610 (Elonex Exentia in UK)
Check that the video cable is securely plugged into the computer and monitor.
Dec 16, 2009 | Computers & Internet
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Keyboard configuration
Control Panel > Region and Language
Change to your locale.
Apr 26, 2009 | HP USB Pos Keyboard PC Desktop
Cannot connect to wireless network
Check the key carefully.
Also check your config carefully
Sep 09, 2008 | Computers & Internet
Taking the Elonex Webbook off of offline mose permenantly
hi there, this is a Firefox 3 vs network manager fight. We are trying to get the full fix pushed out but you can change the setting by going to about:config then changing toolkit.networkmanager.disable this is documented with pictures on my webbook blog
Aug 23, 2008 | Computers & Internet
Gateway 601 (elonex exentia in UK)
Your Gateway (Ethernet) Cable Is Faulty Or Not Connected. Connect It Or If It Is Connected Buy A New One
Jul 02, 2008 | Gateway Computers & Internet
Computers & Internet Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
