Question about EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
Does this motherboard support 64 bit - EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
  • 29 Answers
No this motherboard will not support 64 bit
Posted on Feb 01, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: 32 or 64 bit motherboard?
1.right click on the my computer icon and click on properties
or
2. press windows logo on your keyboard with pause break at same time
Posted on Jul 16, 2008
How do I switch/upgrade my motherboard from a 32bit to a 64bit please
Having a 32-bit or 64-bit operating system mainly depends upon the operating system that is loaded on your primary hard drive (generally drive C:). However, your motherboard's components, i.e., processor and amount of system RAM, will be a major factor in determining whether you can only run a 32-bit operating system, or upgrade to a 64-bit system.
Sep 22, 2014 | Computers & Internet
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
64-Bit??? Ok, when I did the research and looked up the Motherboard and Processor, it states that it's 64-Bit. Yet, it's running 32-Bit (because of the Windows 7 Analyzer). Do I need to set...
Hello Roy,
Did you install Windows 7 32 bit or 64 bit?
You can check by right clicking on "computer" then click on properties.
Then check System Type.
If it says 32 bit and you want to have 64 bit, you should INSTALL windows 7 64 bit on your system.
I hope this helped you.
Nov 05, 2011 | Computers & Internet
Give me the some example of 64 bit operating system and what is the hardware config. to run them like how much ram requierd.
Windows Operating System comes in both 32-bit and 64-bit versions. Examples are Windows XP (64-Bit) and Windows 7 (64-Bit). A 64-Bit Operating System is capable of handling large amounts of data. Hence, it is clear that newer hardware supports 64-bit operation. As for processor Core 2 Duo or higher is required with RAM at least 2 GB or more.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Intel D102GGC2 Motherboard
How do i change from 32 bit to 64 bit on a asus p5q se2 motherboard
The only way to Upgrade from 32 bit to 64 bit is to buy a 64 bit MOBO and replace it with the 32 bit MOBO.
Oct 05, 2010 | ASUS P4P800SE Motherboard
Can support p5gdx2 64 bite
Yes that board is 64 bit compatible. You could load Windows XP 64 bit or WIndows 7 64 Bit. Just make sure you download all the 64 bit drivers from ASUS's site, or it won't work.
Thanks
Mark
May 11, 2010 | ASUS P5GD2-X (610839128686) Motherboard
Is the P5S800 VM MOTHERBOARD 64BIT
can do either one, it depends on operating system you are installing
Feb 07, 2010 | ASUS P5V800-MX Motherboard
Have an ASUS 939 motherboard installed in 2005 with amd 3000+ procecessor got windows 7 installed 32 bit got 3800+ A2 trying to install 64 bit windows 7 and cannot get the 64 bit CD to run I would like to...
first off win 7 is a dvd both 32 bit and 64 bit should be loaded on a dvd drive also you need to go into bios and set (depending which board u have)the board up for hiper and 64 bit some board auto detect
Dec 08, 2009 | Computers & Internet
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Processors
Compatible with Intel 05B/05A/06 processors
Intel
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Regards..
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard Logo
66 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
