Question about Nespresso Aeroccino Automatic Milk Frother
Any reason the frother works at sea level, but not at altitude?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Atmospheric pressure is higher, thus requireing a higher temperature to boil water. That same pressure is what is keeping the bubbles from forming/
Posted on Feb 07, 2010
Does the altitude of 4000 feet has affect on someone with low blood pressure?
I am not a doctor but I can tell you that at 4000 feet there is about 87% of the oxygen compared to sea level. High altitude is usually defined as 5000-11,000 feet. High altitude actually increases the body's blood pressure.
Dec 10, 2016 | Health & Beauty
Will my fuel consumption increase from 3500ft above sea level to 0ft sea level?
It rather depends on how you drive more than the altitude. At sea level, you have more air available, which means you have more power available. If you use the power, then you will use more fuel. If you stay light on the "go" pedal, you will use less.
Last time I was in both cities, Calgary had less traffic, and that may be the reason you're using more fuel in Montreal, not the altitude.
Oct 23, 2015 | 2008 Honda Accord
Sea level altitude
according to the elevation map its 25 meters or 83 feet above sea level
Mar 18, 2014 | Computers & Internet
A person weighs 150 pounds at sea level; what is their weight at 7500 feet altitude?
Here is how I would solve the problem starting from the expression for the gravitational acceleration as a function of the radius. You might not like the fact that I use SI units, but I will show you how to adapt my calculations to suit your needs.
The ratio of the acceleration at altitude h to the acceleration at sea level is a pure number (no dimensions). Just express the Earth radius and the altitude in the same units and your result will be correct.
To get the weight you can write
w(h)/w(at sea level)=g(h)/g, or
w(h)=150 lb* g(h)/g and your result will be in pounds.
If the text of the image is too small, press CTRL + to increase the size. You can also press CTRL- to decrease it.
Dec 21, 2013 | Computers & Internet
Weight at sea level vs. weight at 7500 ft
Hi i have installed a lowrance m52 s/gps in my boat i have turned it on while boat still on trailer and the unit is reading 5.6 ft deep, is this what it should say?
GPS uses satellites to determine position and altitude. Depending on where you are, above or below sea level, it may say you are flying in the air or a few hundred feet below the water. YOU have to determine what your mean altitude is by knowing what the local altitude is above or below sea level. If you were in Denver, Colorado, it would tell you that the boat was about 5,341 feet up in the air. In Death valley you would be below the water because it is below sea level, -272 feet.
Aug 25, 2012 | Lowrance Boating
I just moved from Charleston, SC to Colorado and went from sea level to 6,200 Ft above sea level...do I need to make any adjustments for the higher altitude?
it its fuel injected it will have an atmospheric pressure sensor that compensates for altitude. if its carbs you may have to alter the height of the needle and slightly smaller main jets
Jan 04, 2011 | 2003 Yamaha V Star 1100 Classic
1993 Nissan Altima will crank but won't start - sometimes - altitude issues?
The system is not affected by altitude in this way, the thing you need to check is fuel pressure, this may be pump related.
Oct 22, 2008 | 1993 Nissan Altima
Setting a waypoint, I do not have the altitude and the lowrance will not enter the latitude and longitude, what do I do?
Assume an altitude of zero. It will have little effect on your accuracy even if you are above (or below) sea level. When you are near the waypoint the GPS will tell you the altitude and you can edit the waypoint then.
Jun 11, 2008 | Lowrance LCX-19C GPS Receiver
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Nespresso Aeroccino Automatic Milk Frother Logo
211 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
