Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
How do i change the battery on my honeywell thermastat?
  • grisell915 Feb 01, 2010
    thank you sooooo much! it worked!
  • 306 Answers
You have to remove front cover. Most times there are little snaps on the sides of cover to undo. Get a smallish screw driver and pry the cover off very carefully. any more questions just get back to me ken
Posted on Jan 31, 2010
  • Ken Bledsoe Feb 02, 2010
    If you would just rate my help I would be forever in your debt. My ratings is what I live for helping people and when you see my numbers you know that I am knowing what I am talking about. Okay thanks
Honeywell wifi thermastat 6980??
Try using the calendar and not the cakender set up. Just kidding make sure your press save after you change your settings. Also if that doesn't help doubt it will much try contacting Honeywell either by phone or web site they are very good at assisting contractors or homeowners with questions about a honeywell product.
Nov 22, 2014 | Honeywell Heating & Cooling
How do I get the battery out of the thermastat?
There is often a band under the battery that can be pulled to lift it. The band may not have been placed so that you can.
A pointed object might be used to push in at the NON-SPRING end of the cell and lift it out.
If those fail, try tapping it upside down to shake it loose.
Sep 01, 2014 | Honeywell Heating & Cooling
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Unlock thermastat of honeywell
Do not know what model t-stat you have and they are different depending on what t=stat you have...
Go here and down load the manul for you t-stat which will then tell you how you can unlock it...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
May 06, 2010 | Heating & Cooling
Thermastat temp "fixed" and i do not remember how to adjust it up and down.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 01, 2009 | Honeywell Electronic Programmable...
The digital display is not functioning
the thermostat could be bad. It may have gone bad on its own or due to a short in the supply wiring. Sometimes mice will chew on the wiring in the wall that leads to the thermostat. But I wouls change the thermostat. They do go bad. Make sure you turn the inside unit off first in case you accidently touch wires together. This will blow the transformer inside the unit if the fuse doesn't blow first. I even scene thermostats with fuses inside. So you may want to take the thermostat apart and check for inside fuse also.
Jun 18, 2009 | Honeywell Heating & Cooling
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Our air conditioning was working during the day. when one family member turned the air up from 72 to 75 she saw the screen process what she wanted and walked away. when another family member went to turn...
open the thermostat and look for batteries, 3 AA
http://www.heater-home.com/photos/2129-5b.jpg
http://www.heater-home.com/manuals/th8321u1006manual.pdf
Jun 13, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
226 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
