Question about Toshiba Satellite A135 Notebook
CD/DVD drive does not show up in My Computer and will not play or burn any discs. In Device Manager it says 'This device is working properly' but it is not. Have tried uninstalling and updating drivers just in case, and deleting upper and lower filters but still nothing. It still says it is working properly, but all that happens is that the drive makes the noise as if it's starting up when you put a disc in, then nothing happens.
  • laurawalney Jan 31, 2010
    It doesn't show up in Disk Management. It doesn't show up anywhere apart from in Device Manager and there it just says it's working.Thanks anyway.
  • 748 Answers
Roght click My Computer, choose Manage, and go to Disk Management.
Look there if the drive has a proper drive letter assigned, and change it to some other letter (like V for example). This may help.
Posted on Jan 31, 2010
Li1705 Amilo cd & dvd faults
Dear david read
Your dvd rom is read only,you need a dvd writer to be able to burn cd and dvd
Best Regards
Mazagange
Jan 06, 2013 | Fujitsu Siemens Computers & Internet
My Sony Vaio laptop does not want to play DVD again, only play an burn CDs. use to play an burn DVD put dont even read them now...wierd thing is...when check the info...it say working properly...what is ...
Run thorough virus scan.
Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. They also fail and need to replaced. Mine only reads now. doh!
Nov 25, 2012 | Computers & Internet
Computer will not burn or play disc
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Feb 21, 2012 | BUSlink (DBW1647-FE) DVD RW Dual Layer...
Hey guys, I've fluffed up something on my win7 computer, PIONEER DVD RW DVR-107D ATA Device haven't got a clue what I did to make it go wrong but it no longer plays movie data that I have burned...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 22, 2011 | Pioneer DVR-107D DVD±RW Burner
I have a Sony DVD DRU-820A burner. When I insert a dvd--either a blank one to burn or a DVD disc to view--the name of the drive switches from DVD-RAM Drive (D:) to CD Drive (D:). The burner no longer burns...
The device is _partially_ broken -- the part that reads/writes DVD media is "dead".
Spend $40 to purchase a new CD/DVD reader/writer, to replace the "dead" unit.
Dec 20, 2010 | Sony DRU-820A DVD RW Dual Layer Burner
The player will play dvd and cd. Will not burn
  1. Check the DVD format,maybe the dvd your trying to burn is not supported by your DVD writer
  2. Check the surface of the disc.If is dirty or scratched
  3. Make sure that DMA is enabled on your IDE channels in the "Windows Device" manager(right click on My Computer and select Properties.Hardware->Device Manager )
  4. Uninstall every DVD program you have
  5. Reboot
  6. Verify that your hard drive has enough empty space so it could burn something
  7. Install the program
  8. And try again
Jan 19, 2010 | Gateway Computers & Internet
DVD burner doesn't reconize burned music cd's only shows them as blank disc
Have you tried to play burned music disc with other laptop? if it was able to play there then i suspected your dvd-rom drive is faulty.
To confirm, try playing different cds from your machine and check if it was able to read it.
Jun 03, 2009 | Dell XPS M1330 Notebook
Cannot burn CD or DVD
In the Device Manager, right-click on the DVD drive and select the Uninstall option. Reboot the computer so it will re-detect the drive, reinstall the proper drivers and reset its configuration information. Then try burning the disc again.
Apr 09, 2009 | HP Pavilion dv6326us Laptop
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Playing dvd's
Inside the Control Panels, look for System. Double-click System and choose Device Manager. Inside Device Manager, find the CD/DVD and "Uninstall" the device. Restart the computer and let it re-load the driver. This might help. You can also try a CD/DVD laser lens cleaner.
Nov 12, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Toshiba Satellite A135 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
