Question about Car Audio & Video
Ive got a 97 vauxhall astra estate a few weeks ago i lost the indicators and yesterday the brake lights stopped working to but the hazards and all bulbs are ok
  • kidzrus2 Jan 31, 2010
    ive checked all fuses and relays and they seem fine aswell
  • 10,319 Answers
By the brake pedal a brake light switch is mounted closw by with a plunger on it. Upon pushing on the brake pedal you will see the plunger getting pushed inward a very small bit. It works alkie a light switch. When it is pushed inward the brake lights will come on. Upon releasing the brake the plunger releases turn itself off along with the brake lights. You can take the two wires from the switch and jump them to see if the brake lights do come on to see if the switch is at fault. The two wires are just for the brake lights only for that circuit
Posted on Jan 31, 2010
  • 2,926 Answers
Have you verified the fuse's are not blown??? If so, you'll need a test light to start with basic truoble shooting to correct this issue.
  • GetMeOttaHere Jan 31, 2010
    Ok, What was used to check the relay's???? and what were the results???
2001 4Runner. Car security went bust first, then the horn stopped working, then the hazard lights. Now, the brakes as well. Any help please?
All except the brakes sound like fuses failing, or wires breaking. A quick check of the fuse box should remedy those.
What do you mean by "the brakes"?
does the pedal go to the floor without stopping the truck?
do the brake lights not come on?
is the brake indicator on the dash on?
need a little more to go on
May 13, 2015 | 2001 Toyota 4Runner
Steering is a bit tight + pulls to the left
check your rotors and brakes one may be frozen and not releasing on the left side.
Oct 27, 2014 | Cars & Trucks
Opel Astra 1.6 16v wont start but has power.
The engine light has been an indication you may have a "battery charging problem"...This could be a bad battery, bad alternator, or just dirty battery post connections (or loose) Try the cleaning and tightening of the posts first...(least costly) dirty posts will allow the lights etc to work, but do not allow the full current needed to turn the starter...Hope this helps.
Mar 20, 2014 | Vauxhall Astra Cars & Trucks
Astra center brake light not working
Does the light fixture get power? If so replace the bulb or the whole assembly.
Oct 05, 2012 | Vauxhall Astra Cars & Trucks
Vauxhall astra reverse lights not working
It is located on the outside of the transmission I think.
Oct 02, 2012 | Cars & Trucks
Vauxhall Astra 2002 3door front electric windows not working?fuse's fine.
Hi
I have a vauxhall astra 2002 1.6 sxi. Ive just put in a mirror switch as the last was broken when I purchased car. The switch has been tested and is working but the mirrors dont work? Cant find a fuse which is specifically for that. Can anybody help?
Thanks
David
Jul 28, 2012 | Vauxhall Astra Cars & Trucks
Vauxhall Corsa engine management light
as this a uk car the easiest way to diagnose the problem is to take it into quickfit for a diagnostic check(cost a little,but infinately easier.)and if you want them to fix any problem you cant handle its already in thier workshop(last time i did this was on an astra estate 1.6 petrol,problem was down to faulty exhaust sensor saved me hours of "fun"cost me £38 total.....)
Jul 21, 2010 | Ford Freestyle Cars & Trucks
I need instructions on how to fit the electrics to a vauxhall astra estate 2002 towbar,i have had to put other car make in boxes as it does not show astra estate
You can wire directly into the loom behind the left hand light unit.
The colours are L/H Indicator = Black White, R/H Indicator = Black/Green, Fog = Black/Blue, Brake = Black/Yellow, L/H Tail = Grey/Black, R/H Tail = Grey/Red, and Earth to be bolted to earth point here to.
Jul 04, 2009 | 2002 Volkswagen Eurovan
Vauxhall Astra Envoy indicators not flashing
With out doubt it is the Indicator Flash Unit (Found near fuses) its a plug type box. you pull it out, plug in new one and it works. (Kinda looks like a strange adaptor plug you would put in a power socket.
Jan 12, 2009 | 2004 GMC Envoy
Vauxhall astra hazard lights perminantly on
hi there, just happen to read the problem with your hazard lights. but does the indicators work ptroperly? if not. i would suspect that indicator or hazard lights relay is blown . you can easily replace this diy stuff.. get the part from your local auto parts shop.
Dec 11, 2007 | Umax Astra 3400 Flatbed Scanner
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
