Hello our heat wont shut off. We have a honeywell thermo model TH3210D1004. Can you tell me how to adjust anticipator
  • Ken Bledsoe May 11, 2010
    The heat participator is set from factory for general gas valves. It should be set to the amp draw of the valve it takes a very complicated method to set. I would really suspect the thermostat being bad. How old it the unit? is it loose on the wall causing it to be out of level? Is it digital or mercury?
  • 20 Answers
There is no heat anticipation in the digital thermostats. The thermostat it's self is probably faulty.
Posted on Feb 01, 2010
Put in new Honeywell t-stat. Put new sequencers in. Heat runs for five min shuts off for 2 -5 min then back on continuously. Inside temp stays the same as set point???
What is the model number of the new thermostat? What could be happening is that the cycle rate needs to be changed or if it has a heat anticipator it may need to be adjusted.
Jan 30, 2017 | Honeywell Heating & Cooling
After filling oil tank, turned heater on. does not shut off at 70, keeps running. have to shut heater by emer. shutoff-bad thermostat
Here is the user manual for your unit.
https://www.manualowl.com/m/Honeywell/CT87B/Manual/134033
Look at parts 7&8 of the manual. In section 8 there is a notation about the anticipator pointer adjustment that should solve your problem.
Nov 22, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell lr1620
I do not believe that LR1620 is a model number, you may need to find another number. Try this link to see if maybe it's your thermostat or not. The stamp LR1620 is actually on multiple thermostats. Hope this helps!
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0107.pdf
Read down the PDF file till you see the instructions on setting the heat anticipator.
Dec 01, 2013 | Honeywell Heating & Cooling
How to setup honeywell th3210d1004
you need to change the differential pressure to 3 degrees.that means the unit will not kick on unit it is 3 degrees warmer then the setpoint
Mar 06, 2013 | Honeywell TH3210D1004 PRO 3000...
Heating wont come on. honeywell system the request box in kitchen requesting for it to come on but thermostat not coming on and boiler in garage not kicking into action hve tried resetting both thermo
Check transformer near on on boiler circuit board. the transformer provides a low voltage power source to operate some thermostats and relays at the furnance control board. May need new transformer also check wiring to thermostat
Sep 25, 2017 | Honeywell Programmable Thermostat Heater
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
Honeywell TH3210D1004 thermostat color codes
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 11, 2010 | Heating & Cooling
Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
The furnace shuts off before set temperture is reached
This could be normal. Some thermostats are designed with a heat anticipator. The anticipator takes into consideration heat that will remain within the system after the burners shut down, it anticipates the "left over" heat will be enough for the thermostat to reach it's setpoint. If it did not have this function the setpoint would be overshot.
If you are suggesting it shuts off well below the desired setpoint please clarify.
Dec 01, 2009 | Honeywell Electronic Programmable...
Accuracy
I believe if you take the outer ring off you will see a small resitance strip that is called the heat anticipator. You should see a small pointer that can be moved one direction or another This will adjust for your heat and cooling override.This will tell the furnace to shut off at the temperature you have it set at.
John
Oct 03, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
