Question about Dell Dimension 4600 PC Desktop
Which battery do I need for a dell dimension 8300? How do I get it? How do I install it?
    President:
  • 1,146 Answers
Hi:
If you are asking about the battery that keeps the time of day and date, as well as other computer settings, it isnt too hard to change. It is a coin type battery, and it is mounted on the motherboard. You must unplug the tower, and get the case opened up. After you locate the battery, which is about the size of a nickel, you have to carefully pop it out of the battery holder, and there is usually a small tab to release it. Most of them are a CR2032 battery, which is a 3 volt Lithium battery, which sells for about $2-3 depending where you get it. Install the battery the same way you took it out, usually the flat side up.
plug you computer back in and when it boots up, you should have to set the time and the date, etc, and other computer settings, but you are good to go.
Posted on Jan 31, 2010
I I need a CR3032 battery for my Dell Dimension 4600 dedktop - where can I get one and will any brand do the trick? Checked Dell website and these batteries were not listed
Mary S
Posted on Mar 26, 2010
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
  • 9 Answers
SOURCE: How to remove tower cover...
There are going to be a few small screws on the the back right side (if you are looking at the back of the tower. Remove the the screws from along the edge of the side ( you may have to loosen both sides ) and the case slides towards you then lifts off. If it doesn't budge use a flat head screwdriver to pry in between the cover and tower case and gently slide it towards you. Trust mr it won't break cause it's metal and if it bends you can use pliers to bend it back to shape. Hope the info helps GOD Bless You.
Posted on Mar 21, 2009
whitebirch
  • 433 Answers
SOURCE: I BOUGHT CHEAP RAM, EBAY, DELL DIMENSION 8300 HUMMING
This system supports ECC and non-ECC Rambus modules. ECC and non-ECC modules can be mixed but ECC feature will be disabled. Modules must be installed in pairs. multiple modules - PC800 the max is 2 GBs
systems tool...run disc clean up...put a check mark in every box, you don' need anything there as it is all copies you have elsewhere...
then defraggment also in system tools.
If you really feel like making that ole girl hum, do a complete reinstall using the latest drivers from the dell site. If you use your service tag number it will select the better drivers for your application.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8100&os=WW1&osl=en&catid=&impid=
go to this page for drivers (above) select your operating system (2000-ME-XP-Vista).
hope this helps you. Please leave rating
Posted on May 06, 2009
whitebirch
  • 433 Answers
SOURCE: How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
Posted on May 14, 2009
proton77
  • 1183 Answers
SOURCE: Which lithium battery for dell dimension 8300?
3-V CR2032 lithium coin cell CMOS battery
is what you need.
Thanks
proton
Posted on Jul 05, 2009
I have a dell dimension 8300 and the factory monitor has horizontal lines flickering all over, with intermittent fuzzy haze. Do I need to replace my graphics card to fix this problem? I already downloaded...
Borrow another monitor / if the same download latest vid card drivers / install. (Check cable as well)
If it fixes it either get monitor repaired / replaced.
May 11, 2010 | Dell Dimension 8300 PC Desktop
I installed windows 7 on my dell dimension 8300 and now I have no sound
follow these steps:
1.go to the official site
2.select your device
3.download the sound driver for windows 7
4.instal the driver
5.restart
Jan 08, 2010 | Dell Dimension 8300 PC Desktop
I cant find sound driver
Suggest you download, and install the Audio driver, for the Dell Dimension 8300.
This is Dell Support and Downloads, for the Dell Dimension 8300 Desktop PC,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Sep 04, 2009 | Dell Dimension 8300 PC Desktop
is what you need.
Thanks
proton
Jul 05, 2009 | Dell Dimension 4600 PC Desktop
Driver installation
go to google and type in the product ie dell dimension 8300 mother board driver doun loads and then you follow the instruction
May 23, 2009 | Dell Dimension 8300 PC Desktop
I have installed windows 2000 server on dell dimension 8300 i cant get display and usb drivers
You can try the same XP drivers which is available on the website.
Click Here to download drivers.
Thanks, PREM
Mar 31, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300
Here's Dell's page for changing the battery for a Dimension 8300:
http://support.dell.com/support/edocs/systems/dim8300/sm/battery.htm
Nov 01, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
399 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
