Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027 copier no powew at all
Stopped working all of a sudden not powering up checked the fuse in the plug, it is ok.
Thanks
  • 65 Answers
Another possible cause is to check the main switch. There are 2 on switches on this machine there is one on the top panel, then there is one on the front door panel. The second one is the main power.
Posted on Nov 23, 2008
  • Ricoh Master
  • 691 Answers
The problem may be one of the internal fuses. Whip the side panels off (with the machine unplugged of course) and check the fuses on the power supply boards.
Posted on May 29, 2008
I have a Ricoh Aficio 2500sp copier, a paper got jammed which was released and i closed the door at the side (as normal) the copier stop working as though a fuse went...... Ive checked the plug, socket and...
check at the back of the machine, somewhere around the power cable, there should be a small black trip switch, if that doesnt work then check the fuse on the power supply board after you unplugged the power cable
Nov 03, 2013 | Ricoh Aficio Office Equipment & Supplies
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Gestetner 2712 copier. Won't power on
IT IS SIMILAR WITH RICOH 1012/1022/1027/270.WHAT CAN BE THE PROBLEM IS EITHER YOUR POWER BOARD HAD BURN IC THAT MEAN YOU HAVE TO REPLACE IT OR JUST CHECK THE POWER SOCKET ,MAY BE THE CODED WIRE NOT IN CONTACT WHILE YOU REPLACING THE FUSE,JUST BE CAREFUL AS LIVE WIRE CAN BURN YOUR COPIER.
Mar 17, 2010 | Gestetner 2712 Digital Imaging System...
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Nov 25, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1027 what is the scan option part number?
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
Oct 07, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Aug 10, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027
There are two possible options:
Printer Module (B461)
This requires the 64MB memory option (G579).
Printer/Scanner module
This requires the 64MB memory option (G579) and the NIB (G574).
Good luck and please rate me, thanks.
Nov 04, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
118 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
