Question about Brother DCP 130C All-In-One InkJet Printer
Indication: Paper stuck , open backcover and remove paper; but ther is nothing there and on trying to print: a bad noise and the red light goes on
  • bonmat Jan 31, 2010
    My machine is DCP135C not 1309C
    I tried to run it on thicker paper but the result is the same: Red light and paper stuck msg
    Novelist:
  • 153 Answers
It would be better for you to follow Brother way of troubleshooting paper jam issue on your printer. This would be more accurate.
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=as&c=au&lang=en&prod=dcp130c_all&Cat=4
Regards,
sl4x
Posted on Jan 31, 2010
  • 542 Answers
Check any piece of paper in on the paper sensor. Also check any dust is accumulated on the catride carriage due to which carriage is not freely moving and struck.
Revert back for more assistance.
  • Rajesh Pai
    Rajesh Pai Jan 31, 2010
    Then you need to service the printer with the help of expert engineers or from service center experts.
    Revert back for more asiistance.
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
When printing on HP Laserjet 1320 it brings the red light and it does not shows any error. no printout.
there is a paper in it's roller to remove it pull out the tonner and check the roller ther will be a paper stuck in it remove that papre printing will be contnue
Jan 19, 2011 | HP LaserJet 1320 Printer
Every time I try to print the paper jams. All the paper has been removed, turned it off, still jamming
Found this on the Web, hope it helps you.
If you find this helpful, pls rate me.
Turn your printer off for about 10 seconds, remove the printer cable and then turn the printer back-on. Does only the Green Power Light come on solid [not blinking], as would be normal, or does the Red Error Light also come on? If only the green power light comes on, then try running your printers self-test page, directly from the printer. On most epson printers you can usually run an self-test page to determine whether a problem comes from the printer itself, or possibly from your computer system. Of course if there are actually any red error lights/leds, already showing on your printer, that would indicate that there is already a problem in your printer. Not all epson printers are always the same, but the following information applies to most models. If this self-test does not actually work on your particular printer, then you should refer to your "User's Manual/Owners Manual" for the correct procedure on how to run your printers self-test page. First unhook/unplug the printer cable from the back or side of the printer. Leave the power cord still plugged in to the wall and leave the paper loaded, as normal. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or information that may still have been in the printers system, from when the computer was previously connected. Normally [on most models], you turn the printer off and then you simply reach over and hold-in on the paper button, while you reach over and turn the power button back on, as normal. Continue to hold in on the paper button for about 3 to 5 seconds, but release the power button after turning your printer on. Release the paper button once you can hear and see the printer starting to initialize and start to pull-in a piece of paper. The printer will normally print out the self-test copy, which will also have a nozzle test on it. If that test fails, or cannot actually be ran because the "Red Error Lights" come on, then you know that there is an actual problem in the printer. Depending on the combination of which lights are on SOLID, or FLASHING or OFF, will actually indicate the possible service error condition. Be sure and let us know if you recently had to remove any bad paper jams, by yanking out the paper with force, especially towards the rear of the printer, in the backwards direction. There is a common problem when you get a constant jam condition, or paper won't feed in correctly after a bad jam was removed, or even when the printer or your computer thinks that the paper has not been correctly loaded. If that is the case, then its possible that a part was unhooked/unseated or even damaged, causing a possible constant paper jam condition. If you did have a bad jam, prior to the paper feeding problem, then let us know and we can try to help you further...ON THE OTHER HAND: If everything is working correctly in the printers Paper Feed Assembly, Carriage Assembly/Cartridge Assembly and the Printhead Assembly, then the self-test copy should be printed out and correctly fed thru the printer. If the self-test page prints out correctly and the nozzle test looks ok, then that indicates that your printer thinks it is working normally [as far as the self-test goes].
Thanks and Good Luck.
Jan 25, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Status light indicates a paper problem. Paper try is full and no sign of paper stuck inside the printer.
Could be a few things:
Try poking a small screwdriver in the bottom of the tray to manually lift the paper. If that works, you probably have a gear problem - see the post titled, "Status light is red and paper light blinking"
If that doesn't work, put some paper in the MP tray and test print (hit GO button 3x). If that works, you have a problem with the paper pickup and might require some parts (hard to find). Inside the drive unit (frame L) is a little circuit board (relay front PCB). As you try to print, check voltage on pins 1-2, it should cycle to activate a solenoid. If you get a voltage cycle, your solenoid is probably bad - if not, your relay front PCB is probably bad.
Oct 11, 2009 | Brother HL 5250DN Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Paper
then you have some buried deep inside..turn light off in office, close door, and use a flashlight or penlight..paper will glow from light..that will help a bit..then long tweezers to extract the fragments, eh?
http://tinyurl.com/6qcpgy
Aug 15, 2008 | Brother HL-2040 Laser Printer
Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
I have to open the front panel as though I were going to replace the toner cartridge, but, instead I pull out the toner reclamation cartridge (the gray "L" shaped one to the left of the cyan cartridge) and then put it back in. This has cleared it each time for me.
Aug 10, 2008 | Samsung CLP 300 Laser Printer
Printing Issue
switch off the printer and open up the cover and remove the toner and see is ther any paper is stuck inside. or try to print a single sheet from front panel. bye
Sep 21, 2007 | HP LaserJet 1320 Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
