Question about Kenmore 24032\24036 Top Load Washer
2463200 - loud bang then spin stopped
The washer was in the rinse, spin cycle and then a loud bang...everything came to a stop and the washer was 'humming' until I pulled out the dial to stop the action.
Pushed the dial back in and ran through the cycles...rinse allows water to enter the machine, however, there is no action on the tub...no wash, no spin....
any possible things to look for? - the lid switch is fine.
  • sam21957 Feb 18, 2008
    Yes - humming....nothing else(!)
    voltage as measured at the wall as well as the motors terminal block are OK....
    where is circuit board? and can I do any diagnostics on this??
    Ok - this is where I am at -
    After measuring voltage at wall, through timer, in and out at motor, all was well - the capacitor was humming so I swapped that out at minimal cost knowing full well that this was propably a waste of money - anyway, I took off the motor, transmission and shaft assembly ( also removed water pump from motor shaft) and it ran(!) - replaced everything including water pump and unit was frozen - only after I looked inside the water pump, did I discover a pair of my wifes panty hose which were wrapped around the impeller freezing it up, so when placed back not the motor, it was freezing the motor and the whole shootin' match...
    After four hours, I have the machine back in working order and the wife is now going bare-legged for a while(!) - thanks for the efforts....
    Guru:
  • 1,894 Answers
Hello sir
Posted on Feb 18, 2008
  • 1 more comment
  • dewan nafees ahmed Feb 18, 2008
    ya machine is humming right??
    if so motor is trying to start.. but it is not able to start..
    now check if proper input voltage is coming in for the motor.. if yes then problem must be in next stage where circuit board is placed..
    check it
    thank you
    good luck
    dont forget to rate the solutions
    ok fine
    >>Check the voltage at motor terminals which must be equal to the input voltage.
    >>As soon as u open the machine u can access the main circuit board
    >>also check if power board is working fine
    thank you
    good luck
  • dewan nafees ahmed Feb 19, 2008
    ha hmmmm
    good luck
    thank you
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Maytag Centennial washer makes loud bang and the end of cycle.
I don't think it would be the bearing, as no sounds abnormal occur during it's wash cycle. I think it's at the end of the spin dry cycle, that a "brake" is applied which stops the drum from spin drying, but is being applied overly hard, which causes the drum to "BANG", stop abruptly by the brake. Only a washer repairman could deal with that problem, but, it's NOT dangerous to the washer, IF that's what the problem is. Contact a washer repairman in your area, and they'll probably be able to tell you if it's THAT or something more serious, which I doubt. The reason why the washer moves a bit when at the end of the cycle is probably because the brake which causes the spin dry cycle to come to it's end, does so very fast, which displaces the centrifugal energy abruptly towards lateral motion. Not really dangerous either.
Sep 19, 2012 | Maytag Parts Washing Machines
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
Aug 22, 2012 | Samsung WF231ANW 3.5 cu. ft. High...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
Loud bang during spin
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Aug 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore 24032\24036 Top Load Washer Logo
392 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
