Question about GE DVLR223 Dryers
Will not dry clothes.
GE DVL223EBOWW will not dry clothes. vent hose not clogged, lint trap clean. takes 3 or 4- 80minute cyles to dry.
  • 3,600 Answers
Your heater element may be burnt or you may have to many bends in the vent pipe. also try a smaller load if you still have trouble let me know and I can give you a diagram and tell you things to check in order. You will need a volt meter to do the test and understand the dangers of operating voltage. Also Just for the heck of it try resetting you circuit Breaker for the dryer.
Posted on Jan 31, 2010
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
Taking too long to dry
your lint trap and lint vent are most likely clogged. Easiest way to fix it is to move your dryer away and disconnect the lint vent from the dryer and then take a yard blower to the back of your dryer with a towel around the blower in the hole to ensure the max air moves through the machine. (Ensure the door is only slightly cracked or your house will get very dusty) then clean the lint trap. Then do the same to the lint vent line (make sure the opening of your vent line on the exterior of home is clear of any debris or critter screen) reconnect your vent hose and it should work as new
May 16, 2012 | Kenmore Dryers
The dryer is getting the clothes hot, but not drying. What causes this problem? Thanks
venting issue, you can disconnect vent tube and run a load of clothes if it dries then it is the vent tube, if not then the dryer will need disassembled and all the lint clean out from the lint trap to the end of the dryers vent tube, if is recommended to clean the lint out of the inside of the dryer at least once a year, varying on usage, and the lint screen each time before/after use. Hope this helps Tim
May 22, 2011 | Dryers
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
Dryer has heat but clothes are still wet we dryed a dog pillow that came open and the stuffing went all inside. we took the back off and the shoot for the lint trap but there was no more lint.
If your machine is running properly and you have heat as you say then you may have a clog in the main vent line from the dryer through your house.
Try running the dryer once with the vent hose disconnected. If it dries your know the clog is in the house's vent line. Unusual but it does happen if you have a lot of lint.
Check first at the immediate opening point in the wall there is often a 90 degree elbow where lint can trap.
The other place is the cover plate on the outside of your house. Some at are static and others have vents that open and close. Those too can trap lint and cause a problem.
If you know you have a clog in the house line somewhere but the opening and exit are not clogged then take a drain auger (same as used to clear a clogged toilet) and run it through. If you don't have one try your garden hose.
Good luck.
Please rate if this gives you some direction.
Mar 13, 2010 | Kenmore 62602 Electric Dryer
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Sep 20, 2009 | Dryers
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
GE DVLR223 Dryers Logo
125 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
