Printer began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black stopped printing. I replaced the black - now it prints only magenta. Catch: I bought all cartridges at the same time (two pack deal). Is there a way tell if the printer is "broken" or it just needs new fresh ink, wihtout spending $$ on new cartridges? Thanks in advance!
  • 1 more comment
  • lisalubo Feb 06, 2010
    HP Deskjet 712c Printer
    Sorry, but that is no help except indirectly (see below) as I already did all of that (same info. in users guide and freely available online). Also, my question was about the cartridges not the software. Since I haven't gotten a helpful answer, I unplugged the printer and looked around inside with a flahlight. The cartridge docking station is full of crud as if the cartridges have slowly leaked overtime. I cleaned that out and I am going to see if it does the trick. Info or advice in that area was what I was looking for. - Lisa
  • 265 Answers
I need to know the brand and model of your printer.
Posted on Jan 31, 2010
  • eric1121
    eric1121 Feb 06, 2010
    Run a self-test to determine if the problem is caused by the printer /software or by the computer.
    Running a self-test
    1. Turn the printer on.
    2. Press and hold the POWER button.
    3. Press the RESUME button four times.
    4. Release the POWER button.
    This may need to be performed several times before the printer prints the page.
    If the clean test page prints correctly, the printer and cartridges are functioning properly. Any print quality problem is probably caused by the computer or software. Follow the steps below to solve the problem:
    1. Check your printer software settings. From most Windows applications, click File , Print , then make sure your printer is selected and click Properties . Check the following settings:
    * If you are trying to print in color, make sure Print in Grayscale is not selected.
    * Make sure the Paper Type matches your paper.
    * Set the Quality value as recommended for your paper type. However, if the printout is smearing or bleeding, try reducing quality or increasing speed. On the other hand, if the printout is streaked, light, or does not look filled in, try increasing quality or reducing speed.
    2. Try printing an image (ideally, the same image) from another software application, such as MS Paint. In Windows, you can open MS Paint by clicking Start , Programs , Accessories , then Paint . If the second application prints correctly, there is something wrong with the settings of the first application. Investigate the first application's settings or contact the manufacturer of the first application for help.
    3. Your computer resources may be low. Restart the computer and then try printing again.
    4. Check your printer driver version and update if necessary.
    5. If none of the steps above have solved the problem, remove and reinstall the printer software.
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
Won't print black because magenta color is empty
Refill or replace the empty cartridge.
When you ask to print "black", a small amount of magenta is mixed-in.
No magenta, no print.
Nov 11, 2009 | HP Photosmart D7360 All-In-One InkJet...
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
