Question about Indesit W 123 Front Load Washer
Indesit WIA 121
Will not power up
  • Anonymous Apr 28, 2009
    nothing happening with machine but light is on the front
    Champion:
  • 249 Answers
Check socket, plug .if its none of these's It must be interlock .bye.close Ire.
Posted on Feb 20, 2008
    Novelist:
    Champion:
  • 244 Answers
This could be your interlock this is what sends power if this is not working the washer wont work simple way to test is close the door and bang the front of the washer were the interlock is if its a faulty interlock or a lose wire then it may start up but more then likely that it is the interlock m8
Posted on Feb 19, 2008
4 Suggested Answers
kjmac
  • 97 Answers
SOURCE: indesit wia 121 door lock
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Posted on Jul 28, 2008
Dissolu
  • 221 Answers
SOURCE: washing machine fabric softner problem
Remove the detergent compartment itself and clean it all up. Usually such problem is caused by blocked hole for softener. otherwise check coil continuity of the orange coloured water inlet valve
Update me about your progress
Posted on Jul 25, 2009
SOURCE: indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Posted on Dec 26, 2009
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Hi i need to order new shock absorbers for my washing machine indesit wia 121 uk but there are two types both look the same and i have no part no's on my old ones how can i tell? is there a differance?...
Hi from retired Englishman in SW France @21:31 Sat evening -'cos there's nothing on TV!
You will need the make, model and possibly serial number as reference. These are normally found on a label on the underside of the top of the door surround.
Whoever you are ordering from should be able to supply the correct ones.
Cheers,
John C
Jan 29, 2011 | Washing Machines
HAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Indesit Washing Machines
Indesit WIA 121 not working - door latch not shutting
Oct 05, 2009 | Indesit W 123 Front Load Washer
Indesit WIA 101 Machine wont start.No power
first check the fuse,if this is ok,you will require a main control board,this will require programing for you model and comercial code
Jul 25, 2009 | Indesit W 123 Front Load Washer
Washing machine fabric softner problem
Jul 20, 2009 | Washing Machines
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
Indesit WIA 101
to open do power off after 5 min open the door with power off
Jul 27, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
511 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
