Question about Electrolux Dishwashers
We have a EIDW6305 Electrolux dishwasher. Nothing
We have an EIDW6305 Electrolux dishwasher. Nothing lights up on the display and the dishwasher does not work. Suggestions?
  • 3,741 Answers
As you have as mentioned in your problem that nothing lights up in the unit and dishwasher does not works this indicates that the problem is with your controller board and console assembly and both has to be checked.as the motor is also the other main part which controls the unit but in that case there will be power to the unit.but in your case there is no power to the unit. --------
the other main possibility which you will have to check out is
dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
If your dishwasher doesn't work at all, check these:
Power from the house
Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 31, 2010
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Jul 20, 2014 | Electrolux Dishwashers
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
Dec 02, 2013 | Electrolux Dishwashers
Water isn't draining and display light not working?
what is the model number to your dishwasher? Geraldine
Oct 01, 2013 | Electrolux Dishwashers
Electrolux Dishwasker error code Er 03 model # EIDW6305
this is error E03 is short WASH pump. You need to replace it. the cost is about us$150,00
God bless you
Jul 24, 2013 | Dishwashers
Error code 6
Good Morning sewblessed - Generally, error code E06 means that when the unit is in the dry cycle, the control does not receive the proper speed feedback from the lower fan. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, then more than likely the lower fan will need replacing and I would recommend connecting with an experienced appliance repair tech to assist further.
Jun 14, 2013 | Electrolux EIDW6305GB 24 in. Built-in...
I have the EIDW6305 it's flashing the numbers 77 and 35 on the screen shouldn't be anything what does that mean
Hello Donal Holtman - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel or wiring failure which would need further diagnosing.
Nov 23, 2012 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
Electrolux 5505 dishwasher will not come on - no lights, nothing
Hello Kathy Prussack - I understand you said there are no lights on, however try unplugging the unit or flipping the household breaker off for two minutes to reset. Is there power to the unit? I suggest touching each button individually on keypad, does any lights turn on or does display change? If not, I would recommend contacting a professional because the unit may possibly have a defective keypad.
Sep 30, 2012 | Electrolux 24 in. EDW5500DSS Stainless...
My electrolux dishwasher will not start. lights on the panel are on but will not start
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
I was stressing out because we could not afford a newdishwasher .... The power come on and the unit fills with water, but then does nothing.
Electrolux® Dishwashers - ElectroluxAppliances.com‎
Adwww.electroluxappliances.com/‎rating for electroluxappliances.com
Luxurious by Design, and Featuring the 30 minute Fast-Wash Cycle!
Dec 04, 2011 | Electrolux EDW5505ESS Built-in Dishwasher
Dishwashers Logo
140 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
