How remove blocked icmp automatically
On interface
ip policy route-map test
after adding the above configuration am not able ping any of the public
IPs from same router and my isp are also telling there were not able to ping our IP
But am adding a default route on the router am able ping any IPs from the same router (0.0.0.0 0.0.0.0 isp1 gateway or isp2 or isp3 )
please give the solution for this i can't give default route on the router because my policy ISP1 want use ISP1 one likewise
sathya
  • sathia Feb 18, 2008
    we have three isp connected cisco 1841 router
    we have configured route-map and policy
    isp1 source ip use isp1 gateway
    isp2 source ip use isp2 gateway
    isp3 source ip use isp3 gateway
    configuration as follows
    ip access-list extended isp1
    permit ip X.X.X.X 0.0.0.15 any
    ip access-list extended isp2
    ip access-list extended isp3
    where x = isp ip subnet according isp ip
    route-map test permit 10
    match ip address isp1
    set ip next-hop x.x.x.x (next hop of isp1 IP)
    route-map test permit 20
    match ip address isp2
    set ip next-hop x.x.x.x (next hop of isp2 IP)
    route-map test permit 30
    match ip address isp3
    set ip next-hop x.x.x.x (next hop of isp3 IP)
    on interface
    on interface
    after adding the above configuration am not able ping any of the public IPs from same router and my isp are also telling they were not able to ping our IP
    sathya
  • 56 Answers
Type a "no" before the command of blocking command
e.g:if you want to cancel ip address10.10.10.10
you must type no ip address 10.10.10.10
Posted on Feb 18, 2008
How to Configure the Traffic Statistics Function on S2700&S3700&S5700?
Assume that the statistics on ping packets from 10.1.1.0/24 need to be collected on the interface Ethernet0/0/1 or GigabitEthernet0/0/1. The configuration is as follows:
# Configuration the acl rule.
[HUAWEI] acl number 3333 [HUAWEI-acl-adv-3333] rule 5 permit icmp source 10.1.1.0 0.0.0.255 [HUAWEI-acl-adv-3333] quit # Configuration the traffic classifier.
[HUAWEI] traffic classifier test [HUAWEI-classifier-test] if-match acl 3333 [HUAWEI-classifier-test] quit
# Configuration the traffic behavior:
[HUAWEI] <strong>traffic behavior test</strong> [HUAWEI-behavior-test] <strong>statistic enable</strong> [HUAWEI-behavior-test] <strong>quit</strong>
# Configuration the traffic policy.
[HUAWEI] traffic policy test [HUAWEI-trafficpolicy-test] classifier test behavior test [HUAWEI-trafficpolicy-test] quit # Apply the traffic policy:
  • # Apply the traffic policy test to the S2700 or S3700. [HUAWEI] <strong>interface ethernet0/0/1</strong> [HUAWEI-Ethernet0/0/1] <strong>traffic-policy test inbound</strong>
  • # Apply the traffic policy test to the S5700. [HUAWEI] <strong>interface gigabitethernet0/0/1</strong> [HUAWEI-GigabitEthernet0/0/1] <strong>traffic-policy test inbound</strong>
After the configuration, run the display traffic policy statistics interface interface-type interface-number command to view the traffic statistics. To re-collect traffic statistics, run the reset traffic policy statistics interface interface-type interface-number command to clear existing traffic statistics first.
NOTE:
  • The S2700 or S3700 can collect statistics only on incoming packets.
  • The S5700 can collect statistics on incoming and outgoing packets, but cannot collect statistics on packets sent from its own CPU.
S5700 Switch Thunder link com
Feb 06, 2017 | The Computers & Internet
I need help with cisco asa 5505 ssl vpn.. ssl
The total sum of the Inside/Outside/ and pool address add up to 5,265. Subtract 10% and multiply by 260 to get the gender aspect of the original formula. Move the Network address to Google and download the residual code offered by the program that appears in the open window. Enter the code in the appropriate space provided and this will solve the problem by late 2015.
Oct 09, 2013 | Cisco ASA 5505 Firewall
I have two Cisco routers one is a 501Pix(located at branch Office), the other is a 515E Pix (located at main office). I've configured a vpn tunnel to the router at the main office. The router at the branch...
  1. Please check whether the Tunnel Phase 1 and Phase 2 are Up.If Not Proceed Next, if Yes Proceed to point 4
  2. Please check the peer IP is reachable
  3. Please check the configuration and the encapsulation method used
  4. Check whether in the Match Address whether the IP has been Allowed If Yes Proceed Next
  5. The Branch PIX will be in the Outside interface of the Main PIX, security Level will be enabled so do NAT. If Yes Proceed next
  6. If unable to ping enable the Inspect ICMP in the global policy to enable ping If Yes
  7. If all The above are done. please check the routes between the 2 remote computer.
Please check all the above point, surely your problems will be solved
Feb 26, 2011 | Cisco PIX 501 Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
I need to be able to ping the SonicWall TZ190 wan ip from the Internet for tracert puposes. There is no ping response to that IP address. The manual says. Click Objects, and then Services. Verify that...
Saibrains is correct unless your firmware is of earlier version. you might have to upgrade your firmware. Also you can not use a port #
No ports required for Ping as it uses icmp packets
It needs to allow icmp 'echo-request' (type 8) packets out and icmp 'echo-reply' (type 0) packets in
to allow ping request. On earlier versions of the sonicwall firmware it only absorbed Ping request as to stop hackers from ping attacking pass the firewall.
check the manufactures website for your model and see if they have newwer firmware.
The GUI should have a place where you can set it up
Apr 09, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
My zoom x6 modem doesn't block pings (ICMP). How do I configure?
Blocking ICMP pings on a Zoom requires a few steps:
1) Go to Advanced Setup and select Advanced Firewall Filter.
2) Enable Advanced Firewall Filter.
3) Click on Security Policy Configuration.
4) Click on Policy Rules for "Add Firewall External-Internal Filter Rules."
5) Click on Add Policy Rule.
6) In the row labeled "Protocol," select "neq" and enter ICMP where it says "(Protocol Number or Name)."
7) In the row labeled "Select the direction to filter packets," select BOTH.
8) In the row labeled "Filter Action," select DENY.
9) Click on Save Changes and repeat 1) through 5).
10) In the row labeled "Protocol," select "eq" and "TCP." Below, select BOTH for direction, and ALLOW for filter action.
11) Save changes and repeat 1) through 5).
12) In the row labeled "Protocol," select "eq" and "UDP." Below, select BOTH for direction, and ALLOW for filter action.
13) Save changes.
14) Go back to Basic Setup and save changes to Flash.
That's it. Good luck!
Jan 26, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Automatically ping and trace disabled after PBR
please add me on yahoo messenger or mail me , let me know when ur online , my id is samrat101@yahoo.com and we will be able to resolve it sooner,,, mails takes time.
Samrat
Feb 20, 2008 | Computers & Internet
Route-map policy block the ICMP
honestly, I dont think anyone here will know how to handle this problem. Try to show this problem to a trained professional.
Feb 18, 2008 | Computers & Internet
ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Computers & Internet Logo
308 people viewed this question
Alun Cox
David Payne
David Payne
