Question about Refrigerators
Two days ago I smelled what seemed like a burned motor. Yesterday we noticed the freezer compartment was thawing. It's a two compartment frig, and the refrigerator side seems to still be cooling. How difficult is it to replace the motor?
  • 4,070 Answers
First you need to determine which motor you think is bad. There is a compressor motor which is underneath and around back behind the cardboard cover. If it's not running more than likely the fridge is not cold because it cools both the freezer and fridge.(except in sub zero models and a few others which have separate systems for the freezer and fridge.)
To replace the compressor requires a qualified tech to capture the freon and recharge the system after replacing the compressor.
Another motor is the condenser fan which is also under the fridge near the compressor. It runs when the compressor runs. If it's not running the efficiency of the freezer and fridge will be greatly reduced. This fan can be replaced by a floor fan blowing on the same area until the fan is replaced. It's a job most people can do themselves.
Another motor is in the freezer. It circulates the cold air in the freezer and blows it to the fridge side. If it's not working the freezer will stay cold for the most part but the fridge side will get lots warmer. It's located in the freezer behind the rear cover. It runs when the compressor runs but it will cut off with the door open and entire system will cut off when it's in the defrost mode.
A model number is very important for someone to have in order to help you in diagnosing your problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
It's usually stamped on a small tag in a visible location on your appliance.
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
Posted on Jan 31, 2010
Noticed smell in kitchen yesterday whcih made me think of an electrical issue or motor problem. Wasn't sure where smell was originating from This morning I am hearing a clicking sound from my Whirlpool...
the start device is cooked.pull out the machine and unplug it,remove the bottom panel in the rear and you'll see the compressor,on the side of it you'll see the start device,remove the clip and slide it off the compressor.read the instructions with the new device and install it.if you open the fridge door,look up on the right side wall near the ceiling you'll see the full model number,you need that to get the correct part,you can send it to me or give it to your parts store.the same thing happened to me but i was lucky i had the part in my van,good luck
Jan 23, 2011 | Whirlpool ED5LHAXW Side by Side...
Freezer seems to have stopped working on my Model GSS25JFMD.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 31, 2010 | GE 21.9 Cu. Ft. Side-by-Side Refrigerator...
I smelled an electrical burning smell and noticed that my freezer items were thawing. Is it the motor?
If your refer is over four years old and a Kenmore good odds are higher than not that the compressor has failed.
Nov 22, 2009 | Kenmore Refrigerators
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frig / Freezer not blowing cold air.
your compressor could have chut off.
Jul 27, 2009 | Refrigerators
I have the same problem with my Kenmore refridgerator
To completely clean a frig of bad smells you will need to remove the back cover of frig and freezer compartment to access all areas. I operated a used appliance store for years and had all manner of stinky refrigerators to deal with so what we did was take out all panels and clean out with bleach and water solution. This took care of most odors. Hope this helps.
Jul 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
