Question about Clarion Car Audio & Video
Clarion model RT-9032C AM-FM receiver on/off switch
My Clarion model RT-9032C AM-FM receiver, installed as OEM in a 1987 Mazdda RX-7, has an inoperative on/off switch. If I can find a replacement switch, that would be great. If not, I'd like to find out what contact downstream of the switch should be powered when the switch is on, so I can introduce power to that contact with an external switch. Anyone have a wiring diagram for this unit?
  • jstevens517 Jan 31, 2010
    Since I can't get power thru the internal switch into the radio I see the only solution, other than replacing the switch, to be introducing power downstream of the inoperative switch. Am I missing something?
  • jstevens517 Feb 01, 2010
    Yes, this is very helpful. Thank you.
  • 547 Answers
It sounds like you're trying to introduce an external switch to the inside of the stereo, which would work I guess but it's a lot of work to crack open the stereo and locate the leads.
I think you'll find it far easier to go upstream of the power switch, and introduce an external switch to the power supply in to the radio -- as though the car was turned off.
To do this, just locate the red wire with the black stripe (or black wire with red stripe) on the back of the stereo and introduce your switch there.
If it comes in handy, here's the wiring guide for the rest of the stereo hookup:
Clarion model RT-9032C AM-FM receiver on/off switc - dotted-line-527.gif 1987 Mazda RX7 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/White
Car Stereo Antenna Trigger Wire: Blue/Yellow
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Blue/White
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Posted on Jan 31, 2010
  • Rob C Jan 31, 2010
    Ah, I thought the problem was that the system was always on, and you needed a way to turn it off.
    Sounds like the system is always off, right? Then you're absolutely right that the only fix is inside the unit. I don't have a schematic for that stereo's insides, but 1980s vintage stereos are not very complex.
    I can't tell from the pictures I found if the power is activated by pressing the volume knob, or turning the volume all the way down, but if you look where this control mounts to the board, you'll see a set of 3 or 6 connectors that are small solder bumps. These are the volume controls. You'll also see a pair of larger solder bumps that are the power connections.
    If you use a continuity tester (or meter set to measure resistance) and measure from the 12V Switched wire to these solder bumps, you can locate one that is the power input -- the one that's connected to the 12V switched -- and one that's the downstream side of that switch -- the one that's not connected to 12V switched in.
    I realize this isn't what you were asking for, but hopefully it helps you get some progress.
    For what it's worth, it looks like there's someone trying to sell one of these stereos on eBay, and not finding any buyers. You may be able to contact the seller and make them an offer.
    Here's the first auction, closed with no bids.
    Here's the second auction, also closed with no bids.
    I'm not that seller, and I don't know a thing about his/her stereo.
Have a Yamaha RX-397 switched it on started smoking, switched it off straight away.
open u r RX-397 and see the main supply board inside it whare is u r main power cord is connected their is a capecitor of 200 to 400 volt it is burend so it smoking change it and enjoy
Feb 02, 2013 | Yamaha RX-397 Natural Sound AM/FM Stereo...
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
How do i replace the starter of a 1987 mazda rx7
The starter is mounted on the driver's side bottom of the engine.
  1. Disconnect the negative battery cable.
  2. Raise the vehicle and support it safely with jackstands.
Starter mounting-1986-89 RX-7
  1. Disconnect the heavy battery cable from the terminal marked B on the starter solenoid (or magnetic switch on later models).
  2. Disconnect the thinner ignition switch wire from the terminal marked S on the solenoid/magnetic switch.
  3. On vehicles with automatic transmissions, remove the front starter motor bracket bolts and the bracket. Remove the two starter attaching bolts and remove the starter.
To install:
  1. Support the starter by and hand and position it onto the flywheel housing. Install the two mounting bolts. On 1986-89 RX-7s, torque the bolts to 24-33 ft. lbs. (33-45 Nm). Install the front starter bracket, if removed.
  2. Connect the starter wiring to the appropriate solenoid or switch terminals. On 1986-89 models, torque the B terminal (battery cable) nut to 8 ft. lbs. (11 Nm).
  3. Lower the vehicle.
  4. Connect the negative battery cable.
Mar 06, 2010 | 1987 Mazda RX-7
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Code for Time Warner Synergy V Model RT-U64CP remote
CODE 301 will turn off Yamaha but I don't have code to turn it back on.
Feb 15, 2009 | Yamaha RX-V463 Receiver
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
May 28, 2007 | Clarion DXZ645MP CD Player
Car Audio & Video Logo
130 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
