Question about Samsung TXD1972 19" TV
Power supply wont start
..sir what will i do to convert samsung TXD 1972 (110v) to 220v ?
    Genius:
  • 1,011 Answers
You have to do some alteration for the supply. The conversion can be made with the help of step up transformer (110 in 220 out). This kind of transformer is available in the market. This can only be done by some expert in this field. If you are a technical person and can handle this kind of issue then do it yourself otherwise get it done with the help of expert technician.
good luck
Posted on Jan 31, 2010
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Want to convert hp laserjet 3055 from 110v into 220v
You maybe able to get a new 220v power supply board and swap it out in the printer.
The other way is to get a 110v to 220v step up transformer, make sure the current rating matches or greater than the printer's requirements.
Aug 23, 2012 | HP LaserJet 3055 Flatbed All-in-One...
How do i convert from 120V to 220V
With difficulty, in this case the power supply needs to be replaced with a 220V power supply.
If the current load is small then you can use a set up transformer, but not in this case.
Jul 30, 2012 | Canon imageRUNNER 5000 Copier
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Jun 17, 2011 | Samsung Washing Machines
My Lexmark X9350 All-in-One doesn't turn on.
Actually, the printer's power cord should be plugged in to a power source having 110-220V output. The power supply (the black box behind the printer where the power cord is attached) converts that power to 30V. Basically, if your wall outlet has power output of 110-220V, you won't need a transformer to convert that to 30V. That's the job of the printer's power supply. Hope this helps. If you need more clarification, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X9350 All-In-One InkJet Printer
Powering up
Good day sir, hi, your plasma TV has a module called switching power supply board, this board accepts AC mains 110/220v and convert them to different voltage levels to power your plasma tv. If your TV isn't powering up, this board is the culprit. you need check the fuse of this board or replace this board if the fuse is good. A replacement board is hard to come by, call your dealer if there is warranty, use it. If the warranty has already lapse, inquire your problem to them about the service. thanks.
Nov 11, 2009 | Televison & Video
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
How to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Aug 01, 2008 | Brother Sewing Machines
Televison & Video Logo
79 people viewed this question
Jerry Greenberg
Jerry Greenberg
