Question about Electrolux Dishwashers
Our aeg favorit 35085vi dishwasher doesn't heat water
Our aeg favorit 35085vi is operating but the water does not heat. once cycle has finished plates not completely clean and still wet. Also tablet doesn't dissolve properly. any ideas?
SOURCE: Hotpoint BF1620
hi i had the same problem and what i did was started putting the tablet on the top shelf, making sure it didnt fall through and never found an undissolved tablet since, but we shouldnt have to do this!
terry
Posted on Apr 27, 2008
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Posted on Nov 06, 2008
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
Posted on Nov 11, 2008
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
AEG Favorit 35080vi is not heating water
Hello
You need to take the machine out and remove the top and side panels from it.
(If it's integrated there's no top).
Once you have the side panels off, remove the water in the base of the machine.
Dry out the electrics
Once dried out, try the machine again.
If it doesn't trip and starts working, watch to see where it's leaking from.
Locate the leak, cure it and that should rectify the problem.
Hope this helps
Jan 26, 2012 | Dishwashers
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Water not heating on AEG Favorit 40850.have replaced heater but still not heating.any suggestions
I too have had this problem. I switched to the hottest setting from the economy one and it heated again. Once I switched back it was OK for sometime but has started to do this again.
Jan 30, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Favorit 35085Vi - possible cause of anti flood system being triggered?
It can only be due to a leak running into the base. Suggest you remove RHSide cover and run washer.again. Inspect while running and see where leak is comming from. My guess, its the main motor.
Sep 21, 2009 | AEG Dishwashers
Water not heating. Element replaced with new but still no joy.
The water is heated via a "inductive heater" and not the usual heating elements. This heating device is at the bottom back of the dishwasher and is a cyliderical +/- 15 cm long metal tube. It can easly be removed by the wire clamps at each end. It does have electrical push on connector that just plugs out. If the electrical connections are good I suggest you replace it with a new one (if you can get one).
Mar 23, 2009 | AEG 24 in. Favorit 40660i Built-in...
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Dishwasher
This "Inductive heating element"is in line with the pipe feeding the top spray arm. it is about 15cm long and has a clamp at each end with one electrical push on connecter. It can be reached by taking off the back bottom plate and just follow the spayarm down to this device.
Jun 05, 2008 | AEG 24 in. Favorit 40660i Built-in...
Dishwashers Logo
134 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
