Question about Canopus Spectra 2500 (16 MB) Graphic Card
Image will not show on a tv
I have tried compisit and s-video plugs will show every thing to windows
  • see1 Feb 18, 2008
    plz help
  • 37 Answers
Out of range?
Posted on Feb 20, 2008
    Master:
  • 474 Answers
I would suggest you get a better video card, 16mb card is way to old for todays standard, go get yourself a $60 ATI it will run alot better.
If you want to get it on your t.v. you have to have the T.V. on the right channel, ( AUX) or whatever it has listed for the input, make sure your video card has all the software installed for it, go into the video properties and select the option to show on t.v.
Extended desktop will do that, you drag the mouse off the right side and it shows up on the T.V.
turn this off and it will mirror instead, showing the monitor on the T.V. but with a card that small on power, it might not display the colors very well.
Problem watching video from laptop on TV screen
hold down the windows key on keyboard and the key P
select duplicate screen
select input source as computer or vga on tv
Mar 01, 2018 | The Computers & Internet
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
S-video out to tv nvidia 9300 gforce won't work
obvious things first. have you tried the other input plugs on the TV? do you get the same problem with plugs 1 and 2?
you can try only having the TV connected to the Graphics card and turning on the PC see if it comes up as the primary display automatically.
have you tried configuring the Nvidia setting so ONLY the tv is a display instead of dual monitor?
doing these will rule out faulty cable or faulty S-video plug or Faulty TV input plug.
Dec 07, 2012 | Nvidia 64MB GeForce3 AGP Video Card with...
I just connected my MacBook Pro to my Samsung 46" HD TV and the only thing it shows is the standard galaxy image that is shown at the start up phase. The strange thing is, the galaxy background is not...
What is happening is the Samsung TV is acting as a second monitor. You need to go to system preferences and then displays there will be a check box indicating video mirroring activate that and when that is activated what you will see is what is on your macbook. Hope this helps.
Jun 12, 2010 | Apple 15.4 MacBook Pro Notebook Computer ...
My ps3 wont show an image on to a tv.
try to reset your ps3. hold the power button and it will beep a couple of times do this three times. it will reset your system and work as long as you have no other issues
Jun 06, 2010 | Sony Playstation 3 (PS3) Console
Camcorder will playback ,but shows no image when recording
Can you make it go while attached to a Power Adapter ? and with battery OUT, try that first. IF it works, buy a new battery for that model. Batteries can go so flat they cannot be charged, without special equipment,and even then they may not resurrect. funnily enough, leaving things without current running through them, or powering up,every few weeks, etc, can often cause a problem, strange huh?
Mar 23, 2010 | Canon MV700i Mini DV Digital Camcorder
I am changing from 75ohm to compisite cable hook-up and need to set tv to proper input, how do I do that?
The TV should have an input that is called 'video 1' or 'source 1' etc. consult the TV's operating manual.
Sep 07, 2009 | Sony (ICSSP20) TV Input
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Image retention
most manufactures say not to have a still image on the screen for more than 15% of your viewing time. to fix this you will have to replace the optical assy. i did come across a sony projection where the burn in was actually on the screens themselves. the only thing you can try is to put an all white video pattern on your tv for at least 48 hrs.
Oct 06, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
No image on tv using video card.
If you open the Radeon software utility, in the advanced screen settings you should be able to set "extend my windows desktop onto this monitor" to on for the TV screen. Then all you have to do is open your video player software and drag its window across to the tv, then maximise it. If you are having trouble doing this, some video player programs, especially dvd players playing dvds will not show the picture on the tv. If you want to watch .avi files then the best free player around at the minute is DivxPlayer - go to http://www.divx.com to download. Hope this helps, please ask again if not :)
Apr 06, 2007 | MSI RX300SE-TD128E RADEON X300, (128 MB)...
Canopus Spectra 2500 (16 MB) Graphic Card Logo
59 people viewed this question
Top Canopus Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Canopus Computer and Internet Expert? Answer questions, earn points and help others
