Question about Alesis MasterLink ML-9600
Masterlink The CD tray will not open or close. When the button is pushed it keeps reading scanning disk, but will not release CD.
  • wornout2 Jan 21, 2009
    I have same problem. Have hardly used cd burner at all. Unit is two years old. Alesis rep suggestions did not work. was told to leave unit on for hour and a half, that unit would eventually stop trying to scan disc. That didn't work. Any suggestions other than send it back to Alesis.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
The following assumes you are familiar with the process of removing and installing IDE drives in computers. The CD burner in the Alesis is an IDE device, same as in a PC, and is fitted using same mounting hardware and cabling.
The CD burner isn't connected to the grey front panel flap, so if you open up the machine and release the CD drive from its mounting, and set it so you can see the front of it (ideally on some flat non-conductive material that you can sit on top of the machine) - there's <usually> enough flex in the connecting cables to do this, but....
Most CD drives have a 'release' button on the front (separate from the open/close button) which can be used in emergency to release a reluctant disc. Power on the alesis and press this button (usually done with a thin skewer, cocktail stick, or needle).
If the drive opens and releases your disc, then close it again, put the drive back in its mounting and resume operations with another disc.
If the drive hasn't released the disc, and you have a PC with a spare CD/DVD drive bay, you could try removing the drive from the Alesis altogether, place it in the PC, use the PC to eject the disc, then return the drive to the Alesis.
If the drive doesn't behave in the PC, it sounds like the drive has a mechanical problem and you need to just buy a new drive and fit it to the Alesis. Note - there's only a select list of drives that will work with the Alesis operating system, so make sure you get one that's on the list!
If you're not familiar with how to install and re-install IDE drives, do you have a local geek who builds PCs for a hobby, or a local PC store that offers such services? If so, they should be able to do it with their eyes shut.
Posted on Feb 09, 2009
    Brigadier General:
  • 6,966 Answers
You seem to have two (2) distinct concerns:
1. Mechanical - apparently the CD tray mechanism is stuck hence it won't eject and
2. scanning/reading disc continuously.
Problem 1 would be correctly solved by opening the unit and determining which part cause the eject malfunction. This could either be a cut or slipping belt, stuck gear or misaligned tray guide railings. Alternately, give the unit a solid tap/whack at the top cover central relative to the position of the disc itself. Additionally, some of the moving parts of the DVD mechanism is dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components.
Problem 2 would only come about if: a)dirty, damaged, inverted, blank, un-finalized burned CDs or b) defective, weak, dirty/dusty burned-out laser eye/lens.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Thank you for using Fixya.
Posted on Feb 18, 2008
  • 3 Answers
Benimur's suggestions maybe correct. Just wanted to say that older versions of the OS had a problem with feedback loops occurring whilst trying to address the header data on CD's. Usually the machine would try so many times and then post a "failure to read disk" and return to the menu. When this fails to happen and it continues scanning then this default fails and the machine keeps trying forever...
Its a dead simple fix. Alesis repair agents can do this for you in no time.
Posted on Mar 06, 2008
Sony cfd 646 - cannot open disk tray
Some have a tiny hole in the tray front to manually release it/push the tray open.
Dec 20, 2016 | Sony Televison & Video
Tip
The CD/ DVD/ Blueray player tray keeps opening and closing!
First make sure the "Eject" button has not stuck while pushed-in. Clean the Tray window/opening and the inside of the front part of the tray. Then try to push the tray in a little bit when closed and drag it out while open! By the time dust gathers on the greasy tray rails resulting it not to open and close to the full extent. If it helps but the problem comes back, then you should open the box and clean the rails more thoroughly. Have a look at the switch that senses the tray state (open/closed) too. OBS! That is not the same as the "Eject" button! Switch placement is device model deppendant but it is usually placed on the stationary part of the disc-player unit under the front end of the tray in the middle!
Some units do eject a disk they don't recognize. That a player can't read a disk could be a result of incompatibility, dusty optical lens or faulty/old laser. You may clean the lens by using a "Cleaning disk" or blowing with an air spray(or a straw with your mouth) through the opening of the tray.
Good luck
Please rate positively if helpful, thanks!
/SciPhinx
on May 06, 2010 | Televison & Video
Hello, my otiplex Gx620 cd/dvd drive will not eject the cd it in. Is there any way of releasing it ? many thanks hannah x
Hi and welcome to fixya!
Just follow these few steps and it should fix the problem (but if the problem keeps on happening, it maybe time to change the ODD).
    • 1 Locate the optical drive that contains your stuck disk. You'll see a small hole on or immediately below the disk tray.
    • 2 Straighten the paper clip.
    • 3 Insert the straight end of the paper clip in the hole and push. You should feel it catch inside the latch mechanism.
    • 4 Pull the paper clip out gently. The disk tray will come with it.
    • 5 Remove the CD or DVD and close the tray.
Read more: How to Eject a Stuck DVD/CD Drive ' eHow.com http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html#ixzz1RJn98iTa
Jul 06, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Disk placed wrongly and cannot be read.
  • shut the computer off..
close to the eject button you will find a small pin hole
straighten out a paper clip and push it strongly into the hole and the drivr will pop open.. even if just slightly,, just pull out the draw and remove the disc.. close draw firmly and turn on pc..
the pin hole is there trust me..
Mar 18, 2010 | Acer Computers & Internet
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
CD RESET FAILURE
The CD ERROR 277..can be fixed if u make sure the internal cable connection between the Hard disk and the writer are not mixed up and are well fitted...
Jul 11, 2008 | Alesis MasterLink ML-9600
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Alesis MasterLink ML-9600 Logo
508 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
