Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
The starter rope will not go back in? - Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
  • 111 Answers
The rewind spring end either broke or came out of the rope spool,remove rope start assembly,if you have never done this before, I suggest you have someone who has show you,the spring can get away from you
Posted on Jan 31, 2010
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
Starter rope is broken how do i replace it
Remove the fuel tank and starter cowl, remove snapped rope.wind the pulley to put tension on the spring approx 7-8 rotations. Put a screwdriver through gaps in pulley and through a gap in top of cowl in order to stop pulley from releasing tension. Burn end of new rope and twist end with a rag while still hot to make a point at end ( careful not to burn yourself) then feed the pointed end through rope hole on outside of cowl and through the hole in side of plastic pulley. Tie a knot in the rope once its through and on inner of pulley. Fit starter handle to other end of rope.hold rope and remove screwdriver and slowly feed rope back into starter
Jun 19, 2013 | Briggs & Stratton Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Gx160 pull cord rope broken
1. Buy a starter repair kit or get five feet of nylon rope similar to what was in the starter from a Lowe's, The Home Depot or the like.
2. Remove the three bolts holding the starter on the motor and remove any remaining rope on the pulley.
3. Line the hole in the pulley up with the hole in the starter housing and thread the rope through both.
4. Tie a tight knot in the end of the rope and cut the tail off so it won't interfere with motor but not so short the knot comes undone.
5. Thread the other end of the rope through the t-handle and tie a knot in the very end so the handle won't come off and the rope won't be pulled into the starter during the next part.
6. Pull the rope up between the starter housing and pulley and get the rope into the notch in the pulley. Turn the pulley clockwise with the rope in the notch to put tention on the spring. Give it four turns.
7. When the notch gets back to the hole in the housing, hold the pulley and pull the rope back into place from outside the housing.
8. Let the pulley turn slowly so it retracts the rope.
9. You want four windings on the pulley and the t-handle to be held against the housing. If you don't get four windings on the pulley, give the pulley another tension turn (Step 6). If you have four windings and the t-handle isn't held against the housing or you get more that four windings, shorten the rope at the t-handle.
10. Reinstall the starter and you will be back in business.
Mar 06, 2012 | Honda Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Stihl 026 Chainsaw starter rope is "stiff". When pulling the starter rope, it gets harder to pull at a couple of different places in the rope's path. Then, sometimes it doesn't go all the way...
    Sounds like the little wheel that the rope is wound on is dry. Maybe a little rusty. Open it up and squirt a little oil on all the moving parts and see what happens. I have repaired lawn mower engines by doing that.
    Oct 01, 2017 | Garden
    Starter rope will not retract
    Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
    WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
    Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
    Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
    What I do is the following:
    Remove the old rope ( what is left of it)
    Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
    Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
    Insert the rope and tie a knot, pull the rope back tight against the pulley
    Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
    Starter spring should pull rope into housing... good luck
    Sep 08, 2009 | Garden
    Troy bilt string trimmer starter rope
    you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
    Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
    Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
    175 people viewed this question
    Top Briggs & Stratton Electrical Supplies Experts
    John Trevino
    Falcon52
    Level 1 Expert
    Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
